DESCRIPTION: 2005-UP FORD MUSTANG HYDRAULIC LINE & BLEEDER.
McLeod Racing has brought you another 1st in innovation with the introduction of our new Hi-flow A.N.-4 Stainless Steel Braided Hydraulic Line assembly and bleeder elbow.
This new assembly with allow all 2005-Up S197 Ford Mustangs the ability to bleed the factory hydraulic system, along with reducing the restriction from the OEM supply line from the master cylinder to the internal slave cylinder (Bearing). By reducing the restriction in the hydraulic line this aides in quicker clutch actuation which is beneficial in competition use. Mcleod Racing offers three of the following options.
1) P/N 139250 $75.00 Retail. Fitting elbow connector with bleed screw for wire clip male plug. This fitting allows all 2006.6 Ford Mustangs to utilize their factory OEM hydraulic line and a plug & play feature to bleed end users factory hydraulic system.
2) P/N 139251 $72.85 Retail. Hydraulic Line Assembly 36" AN-4 Stainless Steel Hi Flow Line with Male plug in fittings. This is a replacement alternative to the factory OEM hydraulic line the is equipped in the 2005-Up Ford Mustangs. This Stainless Steel Hydraulic line will be less restrictive which will allow for better flow.
3) P/N 139252 $140.00 Retail. Hydraulic Line Assembly 36" AN-4 Stainless Steel Hi Flow Line with Male plug in fittings and elbow bleeder fitting. This kit has the benefits of both the above mentioned items in one convenient kit.
McLeod Racing - Product Release: 2005-Up Ford Mustang Hydraulic Line & Bleeder
In Stock Ready to Ship!!!
