ok heres the problem.. spary car in second gear from 3500 to about 5500 pulls great shift into third and spray from 3500 to about 5500.. the car pulls till about 4000 rpms then it feels like it falls on its face and i shut the spray off.. im running a compucar kit with a 100 shot at 900 psi in the bottle. tested the wide open throttle switch and its fine. all lines were blown out prior to install. kind of stumped. i tried the shot first with 10 degrees of timing then at 8 still the same thing. im running 39 lbs of fuel pressure with 24lb injectors and a 190 fuel pump. any ideas??? could use all the help i can get.. thanks
not sure on this cause new to nitrous but i got a 255 lph fuel pump on mine to make sure i dont go lean could be that or maybe the bottle is getting cold quick do u have a heater?
