Does any body know where to start looking for the reason for no code 11 when a koeo test is made? i am using a code reader i do get fault codes 95,81 and 82 but no code 11.bad ecu?
87 mustang maf conversion.
so what your saying is i should get a code 11? i did not do the conversion so ill have to check into the relay problem as far as the selanoids go yes they are gone.
I'm new to the site. I'm having surge problems with my 90 mustang gt. when I dump codes i get codes 67 and 22. I've replace maf, iab, and o2 sensors. Can anyone suggest other items to investigate? thanks
Please open your own post and I will post the 5.0 Mustang specific code definitions and fixes for your code 22 & 67. Piggybacking on someone else's post is bad manners, and people tend to ignore you since they may think the problem has already been solved.
