Why would you need to buy mils for a catted X? I just got the 02 extensions for my Bassani catted X and that was it.
Sorry if I confused you...the MIL's=O2 simulators. Swap the MIL's and see if the code swaps to the other bank.by saying that u mean to put the passenger side 02 on the drivers side...vice versa???
i did this but the code still came up as bank#1 below limit...so now what do i do???
i dont have the money to do that...what else can i do??
save for it and drive with the light on it won't hurt anything.
I have MILs and my light is on because of no cats. The car runs fine i just ignore the light.
MIL's suck. Toss them in the trash and go to any decent ford shop. They can turn off the rear O2's in the stock programing.
Using MIL's is like using tape to hold your SFC's on...
do yall know how much that cost??
Did you clear the codes? That is the only other thing I could think of besides what I told you in the PM.
If you did then remove the MIL's completely and see what it does then.
Well, it's far from a custom tune, so between free and $400. I would say it's worth whatever a set of MIL's sells for. It really only takes a few minutes. No dyno needed.
If you have cats then leave the rears alone. Also, you said the SLP X pipe only has one cat?!?! ...not really following you on this one....
