Just a quick question. How loud is your transmission if you shift through the gears while sitting parked with the engine off? I'm talking with the windows down or door open? Can you hear it mesh pretty well or is it relatively quiet??
rebelyell said:04 GT, 2nd and 3rd shift grinds when cold. 1800 miles on odometer
GT JAY said:76* Yesterday and my car is at the dealer with the tranny torn apart!
Supposedly the parts will be in on Wednesday morning.
Johnson505 said:I am still trying to decide if I going to let Ford play with my trans. My trans is notchy going into second and it is somtimes hard to put into gear. It is also makes a strange noise at times. I don't know how to explain the noise. It is like a growl. It is like I can here the gears in the trans spinning. I can't hear it all the time. I notice the sound more often since I installed my short throw shifter. I don't think the shifter has anything to do with it. I could here these sounds when I had my console apart around the shifter. I think the sound travels through my new shifter so I here it more now. Did anyone have these sounds in there trans before the TSB and if so did the TSB fix it? Would a firewall adjuster and new quandrant for the clutch cable fix it or help?
Thanks,
xboxguru said:Hey guys i am recently new owner of a 2002 mustang gt 5spd. I have the same problems 8800 miles and i have a raspy/clunky shift. I want to know if any one has tried bg syncroshift gear oil. I had a DSM about 4 yrs back, eclipse talon, 90-94, anyways its commonly known to dsm owners that bg syncroshift would drastically improve shift quality. My car was grinding second, after install of bg syncroshift it shifted much smoother. Its as close to a rebuild in a can as you can get. Has any one tried this gear oil? I know they have bg syncroshift II out now. Just my .02 cents.
clay
02GTRX said:So has an recall been issued on this??? my gt is in the shop now with the tsb problem, thing is it decided it wanted to start doing it at 53000miles! extended warranty wont doesnt want to cover it because of the tri-ax, how gay is that! charging $1900 to fix it.
Twisted said:It is a design flaw, fluid may help some.
My whole theory is that the 2nd/3rd gear cluster is too heavy and the small syncro cannot speed it up fast enough before the gears have to mesh. If you look at the parts in the service kit the new 2nd/3rd gear is actually thinner from what my dealer told me. They removed some mass and that allows it to spin up, match the mating gear, and mesh smoothly.
