- Dec 28, 2011
- 101
- 0
- 17
Problem: At idle, oil pressure would drop to 0 (stock gauge and yes I know they are crap but dont have a mechanical one lying around) and would raise with acceleration. Cold, the oil pressure stays up, when it gets warm is when this starts happening.
Now I've done some research and have gathered the possible problems together. As I understand, it could be a split block causing the pressure to bleed off, bearings could be shot, oil pump could be bad, or it could be the pressure sending unit. Just now I picked up another sending unit from O'Reillys and slapped that on there.
Bam, thought the problem was fixed. Started her up and the needle sat still, for a bit. Now it still drops to zero, but instead of just staying at 0 like it did, it bounces up and down like a kid on crack in a bouncy castle (no I have never witnessed this occurrence but I would assume it would look something like my oil gauge does after the new sending unit, lol). This leads me to assume it had SOMETHING to do with the sending unit? If the old one wasnt bad why would it change how my oil gauge fluctuates. But if it IS a bad sending unit, why didnt it fix the problem?
My next step will be to cut open the oil filter tomorrow. What should I look for? Im going to cut it open with a hacksaw, will I be able to tell the difference from bearing material and casing material? Can a bad oil filter CAUSE my oil pressure to do what it's doing?
Side note: My car runs fine, no noises. If I had no oil pressure, and it has been like this for awhile (I know I'm stupid) wouldn't my engine be toast already? Surely you cant drive a car around with a broken block... It doesnt leak a drop of oil anywhere.
Im praying that it is the oil filter, but I'm never that lucky. Thanks d00ds.
