I just got done installing the turbo system on my car, I took it around the block last week and noticed when I got back, some coolant had boiled out of the radiator.
Today I looked into it, I thought one of my head gaskets had let go. The temperature would come way up at idle, and when you revved then engine up with the cap of you could see bubbles in the ratiator, along with pushing water out.
But out of nowhere, the temp came down to normal for a second. But soon climbed back up.
So I did a compression test, all cylinder checked out at 130-135. I'm not sure how to interpret that. Is there still a chance a gasket could be bad?
The only other conclusion I tried to come up with was the head lifting under wot and pressurizing the coolant system. And now I have a bunch of air in it, causing my thermostat to work incorrectly?
Any help would be apreciated.
