I was at the track one night when my car all of a sudden popped on the check engine light. Nothing really changed in performance that night. But recently I've have had trouble with the rpm range of 2000-2500 in gear and sitting still in neutral. It does it when its cold and hot. Now the check engine light only comes on when the car is warmed up. The only thing I did before this started was that I installed a Accell coil and ignition box, but it ran fine for a week with it on. I did unhook the ignition box and still had the same problem. I have a brand new set of ford racing wires 9mm and autolite plugs. Any suggestions would be helpful. I will be running a code scan on it tommorow.
