Pertronix Ignitor Setup
Discussion in 'Engine and Power Adder' started by monk302, Mar 11, 2006.
Thread Status:
  1. Selling my Pertronix Ignitor Setup. I am going EFI and don't need this anymore. Make an offer. The following is taken from the web site.
    A solid-state electronic system... "never change points again!"
    Test results show the Ignitor delivers twice the voltage to the spark plugs, increasing horsepower, fuel economy and plug life.
    A 2:1 improvement over point type systems in current fall time for increased coil output.
    System is designed for use with most point-type coils, optimal performance achieved when used with our Flame-Thrower 40,000 volt coil.
    Rotating cobalt magnets, mounted on the distributor shaft, trigger an electronic switching module (Hall effect integrated circuit) points to burn, pit and corrode moving and rubbing parts to wear out.
    Electronics are molded in epoxy, eliminating deterioration from dirt, oil, grease or moisture (better foul weather performance).
    Fits entirely inside the distributor, no "black box" to clutter your engine compartment. Stable timing... no need for any adjustments.
    No complicated wiring makes installations easy. Compatible with 12-volt negative ground systems (some applications available for 6-V negative ground and 6 and 12-V positive ground systems)
    Works great in stock point-type distributors as a trigger for multi spark CD ignitions, eliminating the need for expensive aftermarket distributors.
    California Resources Board E.O. #D-57-2, legal in all 50 states and Canada.
  2. Ill give ya $30 for the modual and coil
  3. Works for me. One thing to note, I don't have a Pertronix Performance coil. Do you have Paypal?
  4. Still Available.
  5. monk, i have paypal. this is just the ignitor set up right, under the cap, and is it new or used? pm me back, thanks. you have a PM
Thread Status:
