Pi Swap Kit Question
Nelmsy
Hi guys i have a 98 GT that im looking to do the PI swap on myself. I found a kit on ebay that looks to have everything included. Here is the link...
http://m.ebay.com/itm/FORD-MUSTANG-...%3A6bdbdc711590a787308234ddffc6e25e%7Ciid%3A1
My question to you guys is do you think that this is a good kit to buy? Will i need anything else for installation? Do i need to degree the cams since they are already in? Will everything basically just bolt up?
Im hoping to follow the write ups ive found for this swap and slowly work on it until im finished. Car is in the garage for the winter so I wont be rushed!
Thanks in advance for your help!
What does "good used heads" mean? I would not put unknown heads on without having them checked/rebuilt due to the cost and time to R/R if they are found wanting after install. For that price I would expect reconditioned heads, but that is me I guess.
Found this on another Forum:
PI Swap Parts List
Found this on the interwebz back in the day when I was looking at doing a head swap. Saved it on my computer and found it today..... please, feel free to add/change as needed!
F5AZ-6700-A (1) Front Cover Crank Seal
F5RZ-6A340-B Crank Bolt
2L3Z-6584-AA Gasket Valvecover
2L3Z-6584-BA Gasket Valvecover
YL3Z-9439-BA Intake Manifold Gaskets
F1AZ 6020-C (1) Front Cover Gasket
F1AZ 6020-A (1) Front Cover Gasket
F6AZ 6020-BB (1) Front Cover Gasket
YF7Z-6279-AA (2) Cam Bolt
F1AZ-6278-A (2) Washer
F1VY-8255-A Seal- Thermostat
F1VY-8507-A Gasket Water Pump
XR3Z 18B402-AA (1) Heater Tube
F8AZ-10153-EA (1) Alternator bracket
F75Z-8555-AA coolant nipple
XR3Z-9L437-BA plenum gasket
XR3Z-9450-AA header down tube gasket
N808140-S431 STUD (for the previously mentioned larger holes in the head)
N808142-S437 SCREW (for the previously mentioned larger holes in the head)
N808529-S309 STUD (for the previously mentioned larger holes in the head)
oh yeah and a 3/8 NPT tap for the extra coolant sensor.
