pictures and video of my sct dyno tune of my blown bird
Discussion in 'SN95 4.6L Mustang Tech' started by blown96bird, Jan 31, 2004.
  1. blown96bird New Member
    Jan 31, 2004
    Message Count:
    35
    I went ahead and got my mildly modified bird dynotuned by sct. These are my mods aed rev 1 kit, headers, dual exhaust, 36#hr injectors, 90 mm L maf, 75 mm tb, 01 pi engine and other minor mods. I initaly started at 301 hp and 315 ftlb of torque when I was all said and done I picked up 27 hp and 49 ftlb of torque for a total of 328 hp and 364 ftlb at the wheels. I made over 300 ftlb of torque at the wheels from 1800 rpm to 5500 rpm. I can punch it rolling 40 mph and roast the tires. What do you think?
    [IMG]
    MY dyno right click and save
  2. cantthinkofname cantthinkoftitle
    Apr 23, 2002
    Message Count:
    3,688
    Ya, here's to The Drunken Clam boys, where they do
    Sponsored Ad
  3. Redfire03GT New Member
    Sep 11, 2003
    Message Count:
    395
    Newark, CA.
    edit: ok, I'm lame, I didn't even read the entire subject of this post. nm
    Good numbers by the way, is that an Allen Supercharger?
  4. blown96bird New Member
    Jan 31, 2004
    Message Count:
    35
    my blower
    It is the allen blower.
  5. Sleepy1 Founding Member
    Jun 10, 2002
    Message Count:
    807
    Chicago, IL
    Congrats, that is one bad bird. My buddy use to have a 91 SC, with all sorts of mods too. But I think yours takes the cake.
  6. blown96bird New Member
    Jan 31, 2004
    Message Count:
    35
    I hate to say this but I love embarasing the 5.0 and 4.6 and camarows/firebirds and ss models. My favorite races were when I raced a supercharged civic and a turbo charged civic they each put 10 k into the engine and I totaly smashed and destroyed them. They thought they were bad because they were runing high 13s and mid 14s
  7. Sleepy1 Founding Member
    Jun 10, 2002
    Message Count:
    807
    Chicago, IL
    Just make sure you stay away from modified camaro/firebirds. They are fast from the factory, but once they start to mod, they are hitting corvette territory.
  8. decoy562 New Member
    Oct 9, 2003
    Message Count:
    1,643
    Acworth, GA
    Cool, post some pics soon! :D I wish I could do that to my T-bird, but it's too freakin old :rlaugh:
  9. oldskooler79 New Member
    Jan 7, 2004
    Message Count:
    76
    Cary, NC
    Are you kidding me? A late-model Firebird/Camaro equipped with an LS1 is beyond corvette territory WITHOUT modifications. You better check yourself.
  10. jadesville the polarbear conservation corps protects a polarb
    Oct 8, 2003
    Message Count:
    2,384
    46
    Gresham, OR
  11. mrvax Stay thirsty my friends
    Dec 26, 2001
    Message Count:
    6,077
    78
    SN Moderator: Orlando, Fl.
    Nice numbers!
  12. blown96bird New Member
    Jan 31, 2004
    Message Count:
    35
    pics of the car and blower
    here is some pictuers. I cut the holes in the bumper for more airflow since the bird dose not have very big openings to let air through compared to a stang it dose run much cooler. The hood is not shut in that picture. It dose have a mustang gt hood scoop that I had to add.
    [IMG]
    [IMG]
    [IMG]
    [IMG]
  13. 1fast03pony New Member
    Jul 1, 2003
    Message Count:
    778
    New york
    I think you should do some better research
  14. yellow5.0cobra Founding Member
    Jul 25, 2002
    Message Count:
    2,871
    In the garage, On the floor.
    I think he was being sarcastic... LS1's NEVER LOSE.
    GREAT CAR!
    Wish you had more detailed shots of the main components... aka S/C'er.
  15. blown96bird New Member
    Jan 31, 2004
    Message Count:
    35
    you asked for it.
    pictures of my blower and other mods and tweeks that I have done or had done.
    It is a nightmare to install headers on the bird. I had to drop my K member and lower the engine down below the frame rails to bolt them up then jack up the motor.
    [IMG]
    The old iron logs
    [IMG]
    I installed a sc 145 spedo and a sc boost vaccum gauge losing volt meter for a volt light big deal
    [IMG]
    magnum powers ported blower
    [IMG]
    The K member out and in the drive not bad to remove hard to install
    [IMG]
    coated to reduce heat transfer.
    [IMG]
    passanger side install
    [IMG]
    It is a real pain to install but aint they purdy
    [IMG]
    custom intake tube that I made
    [IMG]
    opening up the elbow for a 75 mm throttlebody it was 67 mm check bottom picture.
    [IMG]
    opening up the blower inlet
    [IMG]
    ported for pi heads
    [IMG]
    ported manifold
    [IMG]
    very tight.
    [IMG]
    It is sure tight and a real pain to change a belt or tighten the alt
    [IMG]
    ported intercooler not shown
    [IMG]
    [IMG]
    before I ported it
    [IMG]
    Picture of front with heat exchanger while enlarging the holes in bumper bumper cover removed 28000# transmission cooler top center.
    [IMG]
    picture of the modified intercooler. I had the center inlet opened up for 3/4 inch hose for more coolant flow and to quickly reduce the tempetueres of the air charge tempeture if you look close at the manifold you can see a picture of the lightning air charge tempeture sensor. It is there if the act gets to hot it will pull timing and add fuel to prevent detonation.
  16. Redfire03GT New Member
    Sep 11, 2003
    Message Count:
    395
    Newark, CA.
    Not bad.
    Although, if you ever get the chance, you should clean those ports up a tad. I'm not sure what technique you have but, do you use flap wheels? I've noticed that using flap wheels, a wire brush, and a cotton wheel w/ some metal polish works out well. It smooths out the the ports to ap oint where they're almost completely smooth w/ no rough edges.
    Also, if you find a small 3M flap wheel, that'll do wonders for making the ports nice and even.
  17. jadesville the polarbear conservation corps protects a polarb
    Oct 8, 2003
    Message Count:
    2,384
    46
    Gresham, OR
    nice pictures :nice:
Share This Page
