ok i have a set of .030 over pistons w/rods assembled from a 84 302 i tore apart a few years ago. i have a 88 block that needs bored that i want to install them in.
question is do i need to balance the 84 piston/rod assemblies for the 88 crank or should they be both the same and bolt right in? bearing tolerances are within specs so the crank doesnt need reground.
thanks for the help.
