Engine Power Loss, Not Sure Of The Problem.
Discussion in 'Fox 5.0 Mustang Tech' started by James.Little, Apr 26, 2013.
  1. Funny you mention that, I bought some CRC throttle body cleaner just a few moments ago. I figured it couldn't hurt anything. Now, I thought you where not suppose to scratch the throttle body plate, is this true or does it even matter? What are some precautions I should be aware of when cleaning this bad boy?
  2. Yeah breezed over it, but then I fell asleep (I seriously fell asleep, I was tired). I just want to clean it, since it was pretty dirty. I don't think the dirty throttle body is my problem. I am reading that page now. However, the car does starts now, but it still struggles, like in the video.
  3. Here are two resources that you definitely need to make good use of:
    Cranks OK, but No Start Checklist for Fuel Injected Mustangs
    A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
    Revised 12-Dec-2011 to replace 10 pin salt & pepper connector graphic.
    1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
    A.) MSD or Crane ignition box if so equipped
    B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
    C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
    D.) Coil
    E.) No EEC or computer power - EEC or computer relay failure
    86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
    Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
    F.) No EEC or computer power - fuse or fuse link failure
    86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
    G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
    Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
    Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
    H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
    In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
    In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
    You'll find it up next to the starter solenoid where the wire goes into the wiring harness
    I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
    J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
    K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
    Wiring Diagrams:
    See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
    Ignition switch wiring
    Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
    http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
    Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
    http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
    AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | AutoZone.com and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
    2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
    B.) Distributor cap
    C.) Rotor
    D.) Spark Plug wires
    Two reasons:
    Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
    [​IMG]
    If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
    C.) Clogged fuel filter
    D.) Failed fuel pump
    A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
    A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
    I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
    B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
    C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
    See the graphic for the 10 pin connector circuit layout.
    [​IMG]
    The injector power pin is the VPWR pin in the black 10 pin connector.
    D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
    E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
    It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
    6.) Spark & fuel pressure OK.
    A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
    C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
    HO & 351W 1-3-7-2-6-5-4-8
    Non HO 1-5-4-2-6-3-7-8
    E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
    Once the startup problems are fixed, dump the codes...
    Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
    Dumping the computer diagnostic codes on 86-95 Mustangs
    Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
    Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
    Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
    Post the codes you get and I will post 86-93 model 5.0 Mustang specific code definitions and fixes. I do not have a complete listing for 94-95 model 5.0 Mustangs at this time.
    Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. On a manual transmission car, be sure to press the clutch to the floor.
    Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    What to expect:
    You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and driveablity problems
    Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
    Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, and clutch (if present) is pressed to the floor, and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
    Your 86-88 5.0 won't have a working Check Engine Light, so you'll need a test light.
    See AutoZone Part Number: 25886 , $10
    [​IMG]
    Alternate methods:
    For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
    Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30-$36.
  4. Okay so I pulled the codes. I don't have a check engine light or a automotive light so I tossed together a LED, 9V battery, and some alligator clips and was able to read the output. Now I am not the best at understanding what I am seeing so I made another video. I counted this:
    219
    5219 (<-what?)
    View: http://www.youtube.com/watch?v=Miar8tq4KP8&feature=youtu.be
    I have a video with it running, somewhere.
    Edit: Never mind it is corrupt for some reason, I will have to redo that because I didn't count.
  5. 86-93 Mustangs have 2 digit codes
    94-95 Mustangs have 3 digit codes
    No Mustang has 4 digit codes.
    What year is your car? It looks like you may need to try again. An external battery is not needed when dumping codes. You use the car battery to power the LED or light.
    The computer check engine light tan wire on the computer diagnostic connector is used to provide the ground for the test light.
  6. Yeah I know that is why I am confused. The motor is an 88 and the body is a 89. However, I did a MAF swap and I put in a A9P ECU (I have a 5-speed, I think I am going to change it to A9L sometime).
    Yeah I got to thinking, I could have just eliminated the 9v battery. I guess I was worried about over amping the LED. I used the 9v power to the LED and connected the 9v ground to the system ground and grounded the LED using the diagnostic harness (for details, see here: http://imgur.com/a/Tj23l) I think I am just going to use the car battery next time.
    Yeah I did not have the engine warmed and I lost the video with the engine on. So let me double check:
    1. I need to let the engine warm up
    2. Key On, Engine Off
    3. Count On's (1's), how do I know when to stop?
    4. Key On, Engine On
    5. Count On's (1's), again, how do I know when to stop?
    * I know that it will rev the engine up for a bit then it will bring it back down (it did this the first time), do I count before or after it revs the engine?
    6. ???
    7. Profit.
  7. Do not use the car battery unless you like a dead pcm. The diagnostic wire r/w I believe only has 5 volts across it. Put 12 and I'll be showing you how to solder a jumper in for your signal ground return that you fried out.
  8. That does not really make any sense. If you use the check engine light, it is using the car battery. If you are using an automotive light, it is using the car battery. Also the LED I am using has a built in resistor. There will be no harm done.
  9. The line used to get power for your check engine light goes to the.pcm. this ground is the reference for all the sensors the pcm uses to (think) if you jump it with (say a paperclip) it burns out the signal return on The pcm board.. a lot of times this happens when someone uses the power for the hood light instead of the 5v reference supplied at the diagnostic port. This happened to me luckily I am an electrician I just pulled her apart and soldered in a jumper. So just take it from someone that has experienced this first hand.
  10. Wrong answer.
    Remember that the computer does not source any power to actuators, relays or injectors, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit. This method is called current sink technology. It is used extensively in computer controlled circuits be cause the circuit can be shorted to ground and never do any damage to the computer.
    The check engine light is wired to switched 12 volts coming from the ignition switch. The computer switches the tan wire to ground, completing the circuit and causing the check engine light to turn on. Wire a LED connected to the battery and the other to the tan wire and the LED will light when the computer switches the tan wire to ground. It will not do any damage to the computer.
    Got any doubts? I have been fixing computers for 35 years and 8 of those years was spent chasing 1's and 0's on circuit boards with an oscilloscope. I have a very good understanding how electronics and computers work.
  11. Look up (computer issues) go ahead short the signal return to 12 v and tell me I'm wrong again. Same thing happens when you use the wrong o2 harness. You walked me through that fix yourself.
  12. Okay so I checked the codes again and double checked and here is what I got:
    Key On, Engine Off:
    95
    95
    Memory (1):
    29,
    66,
    95,
    29,
    66,
    95
    Key On, Engine On:
    21,
    26,
    36,
    33,
    21,
    28,
    46,
    33.
    So what do these mean?
  13. O:
    95 - Fuel Pump Circuit Open-PCM To Motor Ground (CM,O)
    M:
    29 - Insufficient Input From Vehicle Speed Sensor
    66 - , MAF signal below minimum test voltage of .4vdc
    R:
    21 - Engine Coolant Temperature (ECT) Sensor Out Of Self Test Range. 0.3 to 3.7 volts(O,R)
    26 - MAF sensor was not between 0.2 and 1.5 volts with engine running (R).
    36 - System Indicates Lean At Idle (R)
    33 - EGR Valve Opening Not Detected (CM,R)
    28 - Loss Of Ignition Diagnostic Module RH Side (CM)
    46 - Secondary Air Not Bypassed During Self Test (R)
    I guess I have my work cut out for me. I have a couple of questions here.
    How can I check my fuel pump ground? Where the heck is my ECT sensor? What does it mean that my systems is running lean, is that because of the faulty fuel pump? I guess my EGR valve is bad? I don't even understand codes 28, 29 and 46. Any thoughts?
  14. Shorting the signal return and 12 volts together is not the same as placing a LED between 12 volts and signal ground. The LED will limit the current flow to 20 Milliamps or less. That isn't going to hurt the signal ground.
    Code 95 Key On, Engine not Running - the following test path is for 86-90 model Mustangs.
    The 95 code is because at one time or another, the fuel pump relay hiccupped and didn't provide power the pump when the computer told it to run. Sometimes this is a one time thing, other times it is a no run or runs poorly condition.
    [​IMG]
    Using the diagram, check the red/black wire from the fuel pump relay: you should see 12 volts or so. If not, check the inertia switch: on a hatch it is on the driver’s side by the taillight. Look for a black rubber plug that pops out: if you don't find it, then loosen up the plastic trim. Check for voltage on both sides of the switch. If there is voltage on both sides, then check the Pink/black wire on the fuel pump relay: it is the power feed to the fuel pump. No voltage there, check the Orange/Lt blue wire, it is the power feed to the fuel pump relay & has a fuse link in it. If there is good voltage there & at the Pink/black wire, swap the relay.
    Some Mass Air conversions neglect to run the extra fuel pump wire, and they always have a 95 code. See http://www.stangnet.com/tech/maf/massairconversion.html for more information on the Mass Air wiring conversion.
    See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
    Vacuum diagram 89-93 Mustangs
    HVAC vacuum diagram
    TFI module differences & pinout
    Fuse box layout
    Code 29 - Vehicle Speed Sensor (VSS) is an electronic sender mounted on the speedo pickup gear on the trans. It works the cruse control for both 5 speed and auto trans cars. The VSS is used to tell the computer to speed up the idle as you slow to a stop. This helps keep the engine from stalling when you slow down for a stop sign or stop light.
    Check to see if the electrical connector is plugged into it. Clean the connector & contacts with non flammable brake parts cleaner prior to replacing the sensor, as that may fix the problem. The sensor cost is under $30 and it is easy to replace.
    Note: If your car was a Mass Air Conversion, these two codes are symptoms of some wiring that didn't get done durning the conversion.
    Code 66 MAF below minimum test voltage.
    Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
    There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables. Changes in RPM causes the airflow to increase or decrease, changing the voltage output.. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow.
    The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
    Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer. Be sure to measure the sensor output by measuring across the pins and not between the pins and ground.
    At idle = approximately .6 volt
    20 MPH = approximately 1.10 volt
    40 MPH = approximately 1.70 volt
    60 MPH = approximately 2.10 volt
    Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
    There should be a minimum of 10K ohms between either pin C or D on the MAF wiring connector and pins A or B. Make your measurement with the MAF disconnected from the wiring harness.
    Code 21 – ECT sensor out of range. Broken or damaged wiring, bad ECT sensor.
    Note that that if the outside air temp is below 50 degrees F that the test for the ECT can be in error. Warm the engine up until you get good hot air from the heater and then dump the codes again.
    The ECT sensor has absolutely nothing to do with the temperature gauge. They are different animals. The ECT sensor is normally located it the passenger side front of the engine in the water feed tubes for the heater.
    The ACT & ECT have the same thermistor, so the table values are the same
    ACT & ECT test data:
    Use Pin 46 on the computer for ground for both ECT & ACT to get most accurate readings.
    Pin 7 on the computer - ECT signal in. at 176 degrees F it should be .80 volts
    Pin 25 on the computer - ACT signal in. at 50 degrees F it should be 3.5 volts. It is a good number if the ACT is mounted in the inlet airbox. If it is mounted in the lower intake manifold, the voltage readings will be lower because of the heat transfer.
    [​IMG]
    Voltages may be measured across the ECT/ACT by probing the connector from the rear. A pair of safety pins may be helpful in doing this. Use care in doing it so that you don't damage the wiring or connector.
    Here's the table :
    50 degrees F = 3.52 v
    68 degrees F = 3.02 v
    86 degrees F = 2.62 v
    104 degrees F = 2.16 v
    122 degrees F = 1.72 v
    140 degrees F = 1.35 v
    158 degrees F = 1.04 v
    176 degrees F = .80 v
    194 degrees F = .61
    212 degrees F = .47 v
    230 degrees F = .36 v
    248 degrees F = .28 v
    Ohms measures at the computer with the computer disconnected, or at the sensor with the sensor disconnected.
    50 degrees F = 58.75 K ohms
    68 degrees F = 37.30 K ohms
    86 degrees F = 27.27 K ohms
    104 degrees F = 16.15 K ohms
    122 degrees F = 10.97 K ohms
    140 degrees F = 7.60 K ohms
    158 degrees F = 5.37 K ohms
    176 degrees F = 3.84 K ohms
    194 degrees F = 2.80 K ohms
    212 degrees F = 2.07 K ohms
    230 degrees F = 1.55 K ohms
    248 degrees F = 1.18 k ohms
    [​IMG]
    Code 26 - Mass Air Flow out of range – MAF
    Look for 12 volts across pins A & B.
    The MAF output varies with RPM which causes the airflow to increase or decease. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow. Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer.
    There should be a minimum of 10K ohms between either pin C or D on the MAF and ground.
    Code 33 - Insufficient EGR flow detected.
    Look for vacuum leaks, cracked vacuum lines, failed EGR vacuum regulator. Check to see if you have 10” of vacuum at the EGR vacuum connection coming from the intake manifold. Look for electrical signal at the vacuum regulator solenoid valves located on the rear of the passenger side wheel well. Using a test light across the electrical connector, it should flicker as the electrical signal changes. Remember that the computer does not source any power, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
    Check for resistance between the brown/lt green wire on the EGR sensor and pin 27 on the computer: you should have less than 1.5 ohm.
    Backside view of the computer wiring connector:
    [​IMG]
    http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
    EGR test procedure courtesy of cjones
    to check the EGR valve:
    bring the engine to normal temp.
    connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connnect the test jig or to directly to manifold vacuum.
    Do not connect the EGR test jig to the EVR (Electronic Vacuum Regulator).
    apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
    if engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
    if engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
    if engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
    Use your finger to cap the open port on the vacuum tee.
    snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
    did the vacuum gauge show about 2-5 in vacuum?
    if not the EVR has failed
    EGR test jig
    [​IMG]
    The operation of the EGR vacuum regulator can be checked by using a test light applied across the wiring connector. Jumper the computer into self test mode and turn the key on but do not start the engine. You will hear all the actuators (including the EVR vacuum regulator) cycle. Watch for the light to flicker: that means the computer has signaled the EGR vacuum regulator successfully.
    Some basic theory to clarify how things work is in order…
    EGR System theory and testing
    The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops combustion temperature, increases gas mileage and reduces the tendency of the engine to ping. It can also reduce HC emissions by reducing fuel consumption. The primary result of EGR usage is a reduction in NOx emissions.
    The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum regulator. The EVR is located on the back of the passenger side shock strut tower. The computer uses RPM, Load. and some other factors to tell the EVR to pass vacuum to open the EGR valve. The EGR valve and the passages in the heads and intake manifold route exhaust gas to the EGR spacer (throttle body spacer). The EGR sensor tells the computer how far the EGR valve is open. Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
    [​IMG]
    Troubleshooting:
    There should be no vacuum at the EGR valve when at idle. If there is, the EVR (electronic vacuum regulator) mounted on the backside of the passenger side wheelwell is suspect. Check the vacuum line plumbing to make sure the previous owner didn’t cross the vacuum lines.
    Diagram courtesy of Tmoss & Stang&2birds. (the diagram says 88 GT, but the EGR part is the same for 86-93 Mustangs)
    [​IMG]
    The EGR sensor is basically a variable resistor, like the volume control on a radio. One end is 5 volt VREF power from the computer (red/orange wire). One end is computer signal ground (black/white), and the middle wire (brown/lt green) is the signal output from the EGR sensor. It is designed to always have some small voltage output from it anytime the ignition switch is the Run position. That way the computer knows the sensor & the wiring is OK. No voltage on computer pin 27 (brown/lt green wire) and the computer thinks the sensor is bad or the wire is broken and sets code 31. The voltage output can range from approximately .6-.85 volt.
    The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70 Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches the ground on and off to control the regulator solenoid.
    To check the EGR valve:
    Bring the engine to normal temp.
    Connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connnect the test jig or to directly to manifold vacuum.
    Apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
    If the engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
    If the engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
    If the engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
    Snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
    Did the vacuum gauge show about 2-5 in vacuum?
    If not the EVR has failed
    EGR test jig
    [​IMG]
    To test the computer and wiring to the computer, you can use a test light across the EVR wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker. If the test light remains on the computer or the wiring is suspect.
    To check the EVR to computer wiring, disconnect the EVR connector and connect one end of the Ohmmeter to the dark green wire EVR wiring. Remove the passenger side kick panel and use a 10 MM socket to remove the computer connector from the computer. Set the Ohmmeter to high range and connect the other ohmmeter lead to ground. You should see an infinite open circuit indication or a reading greater than 1 Meg Ohm. If you see less than 200 Ohms, the dark green wire has shorted to ground somewhere.
    Late Model Restoration may still have the Ford Racing M-12071-N302 kit with the EGR valve & sensor along with the ACT & ECT sensors for $45. See http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=M12071N302 1&comp=LRS for more details
  15. Reread post 30 I did say paper clip.
  16. Okay so, I still don't understand some of these codes, but I am guessing that if I replace my ECT sensor and fix my EGR valve problem that some of those codes will go away. However, will they fix my start up problem? You know where I have to hold down the throttle to get the engine started (it is getting worse and worse). When I get paid this weekend I am going to buy a new cap and rotor and possibly a check on my fuel pressure. Any body have any thoughts of my problem or are we still thinking a good tune up will fix it?
  17. We are talking apples and oranges.
  18. The startup symptoms you are describing are due to lack of airflow when the engine cranks. That is because the IAC/IAB isn't working, is sticky/dirty or the base idle isn't set correctly.
    IAC doesn't work: look for +12 volts at the IAC red wire. Then check for continuity between the white/lt blue wire and pin 21 on the computer. The IAC connector contacts will sometimes corrode and make the IAC not work. The red wire on the IAC is always hot with the engine in run mode. The computer provides a ground for the current for the IAC. It switches the ground on and off, making a square wave with a varying duty cycle. A normal square wave would be on for 50% of the time and off for 50% of the time. When the idle speed is low, the duty cycle increases more than 50% to open the IAC more. When the engine speed is high, it decreases the duty cycle to less than 50% to close the IAC. An old-fashioned dwell meter can be used to check the change: I haven’t tried it personally, but it should work. In theory, it should read ½ scale of whatever range you set it on with a 50% duty cycle. An Oscilloscope is even better if you can find someone who has one and will help.
    [​IMG]
    Recommended procedure for cleaning the IAC/IAB:
    Conventional cleaning methods like throttle body cleaner aren’t very effective. The best method is a soak type cleaner used for carburetors. If you are into fixing motorcycles, jet skis, snowmobiles or anything else with a small carburetor, you probably have used the one gallon soak cleaners like Gunk or Berryman. One of the two should be available at your local auto parts store for $22-$29. Take the solenoid off the body and set it aside: the carb cleaner will damage some types of plastic parts. Soak the metal body in the carb cleaner overnight. There is a basket to set the parts in while they are soaking. When you finish soaking overnight, twist the stem of the IAB/IAC that sticks out while the blocker valve is seated. This removes any leftover deposits from the blocker valve seat. Rinse the part off with water and blow it dry with compressed air. The IAC/IAB should seal up nicely now. Once it has dried, try blowing through the bottom hole and it should block the air flow. Reassemble and reinstall to check it out.
    Gunk Dip type carb & parts soaker:
    [​IMG]
    Setting the base idle speed:
    First of all, the idle needs to be adjusted to where the speed is at or below 600 RPM with the IAC disconnected. If you have a wild cam, you may have to raise this figure 100-150 RPM or so. Then the electrical signal through the IAC can vary the airflow through it under computer control. Remember that the IAC can only add air to increase the base idle speed set by the mechanical adjustment. The 600 RPM base idle speed is what you have after the mechanical adjustment. The IAC increases that speed by supplying more air under computer control to raise the RPM’s to 650-725 RPM’s. This figure will increase if you have a wild cam, and may end up between 800-950 RPM
    Remember that changing the mechanical idle speed adjustment changes the TPS setting too.
    This isn't the method Ford uses, but it does work. Do not attempt to set the idle speed until you have fixed all the codes and are sure that there are no vacuum leaks.
    Disconnect the battery negative terminal and turn the headlights on. Leave the battery negative terminal disconnected for 5 minutes or so. Then turn the headlights off and reconnect the battery. This erases the computer settings that may affect idle performance.
    Warm the engine up to operating temperature, place the transmission in neutral, and set the parking brake. Turn off lights, A/C, all unnecessary electrical loads. Disconnect the IAC electrical connector. Remove the SPOUT plug. This will lock the ignition timing so that the computer won't change the spark advance, which changes the idle speed. Note the engine RPM: use the mechanical adjustment screw under the throttle body to raise or lower the RPM until you get the 600 RPM mark +/- 25 RPM. Changing the mechanical adjustment changes the TPS, so you will need to set it.
    When you are satisfied with the results, turn off the engine, and re-install the SPOUT and reconnect the IAC. The engine should idle with the range of 650-750 RPM without the A/C on or extra electrical loads.
  19. Okay I know you said to soak it overnight in carb cleaner, but I went ahead and used throttle body cleaner, some Qtips, and a couple of hours till it was bright and shinny again. I also did this to the ports on the throttle body as well. After attaching the IAC back on it started up better than it has been, but it still hesitated. It is also it idles lower than ever, like it wants to die but its just enough to keep it alive. I am going to replace my ECT sensor, sense they are cheap, but could someone tell me where it is? I have been searching for it on the internet and I cannot find a good description or picture that points it out.
