power steering pump
95Monky
179
Chico, CA
my power steering pump pulley is loose and slide into the bracket that holds the pump.. it seems either the bolt is stripped or the pump shaft is. my problem is the bolt wont come out it.
I have nver changed a pump so hang with me. does the pulley need to pulled off and pressed back on the new pump? how do i stop the pump from turning so i can remove the bolt?
