How can a direct port injected intake manifold have distribution issues?
I can see how that would be the issue if you were using a plate N20 system, since the spray nozzles are sandwiched between the upper, and lower and the enrichment fuel has to travel through the plenum, and the runners. But with a forced induction system, how can there be any less fuel delivered at any port when the injectors are all the same distance from the intake valve?
If this was a carbureted system, and that was a typical Vic/Super Vic, then I'd agree that runners 1,4,5, and 8 get starved. (sometimes 7 and 8) because of the longer runners off the plenum, and it wouldn't matter whether there was a plate nitrous system under that carb, or a "hat" on top getting blown through,.....those cylinders are typically a problem when there is old school tech fueling the engine.
Nitrous is a pain in the ass. Simply because it runs out. It's almost comical to see how many bottles of the stuff that N20 racers bring to the track ( or how many 50 pound refill bottles big budget N20 racers bring to the track) to be sure that the two or three bottles they are carrying in the car are full all the time.
Turbo baby. Specifically Chinee turbo of the GT 45 variant. If you are a capable fabricator you can Chine-if-icate a system together for well below 1000.00, and there are plenty of examples of that stuff working perfect to offset the examples of it not.
Unless you are class racing in some form of H/U racing, I'd ditch the power adder altogether. If you bracket race, you don't get paid one cent more to win whether the car goes an 11.0 or an 10.0, so why add the potential for tire spin, and inconsistency?
