Cook89Notch Founding Member Jan 17, 2002 3,201 8 59 Close to Lansing, MI. Apr 20, 2006 #1 Apr 20, 2006 #1 I'm hoping it's 5.5. Someone has some Draglites for sale in the classifieds, I need to get some so I can flog my car with a set of ET Streets! Thanks in advance ~Matt.
A a97mustang New Member Feb 2, 2006 61 0 0 Lincoln Park michigan Apr 20, 2006 #2 Apr 20, 2006 #2 cook call mccormick racing for backspace there in lincoln park if i can find the number i will post it.
blackfang Founding Member Dec 17, 2001 1,290 1 39 Richmond, Va Apr 20, 2006 #3 Apr 20, 2006 #3 Just measure the stock wheel. measure from the back part of the wheel to the mounting pad. You need 5.5" minimum
A a97mustang New Member Feb 2, 2006 61 0 0 Lincoln Park michigan Apr 20, 2006 #4 Apr 20, 2006 #4 97 have a bar over the caliper so its wheel spacer time or grinding the bar.(weld wheels)
Cook89Notch Founding Member Jan 17, 2002 3,201 8 59 Close to Lansing, MI. Apr 21, 2006 #5 Apr 21, 2006 #5 Good info, thanks guys!
Cook89Notch Founding Member Jan 17, 2002 3,201 8 59 Close to Lansing, MI. Apr 23, 2006 #6 Apr 23, 2006 #6 a97mustang said: 97 have a bar over the caliper so its wheel spacer time or grinding the bar.(weld wheels) Click to expand... Oh crap! How much grinding would I have to do? If it's not much, then that's what I'll do. How about installing rear brakes from another year? Thanks, Matt.
blackink00 I missed a shift & stole Curt's money. Mar 30, 2005 545 0 0 Tempe, AZ Apr 23, 2006 #7 Apr 23, 2006 #7 well it is 5.5" back spacing and no you shouldnt need to grind anything. should just bolt right on. didnt need to do anything to my draglites. 15x8
Cook89Notch Founding Member Jan 17, 2002 3,201 8 59 Close to Lansing, MI. Apr 23, 2006 #8 Apr 23, 2006 #8 blackink00 said: well it is 5.5" back spacing and no you shouldnt need to grind anything. should just bolt right on. didnt need to do anything to my draglites. 15x8 Click to expand... Cool, what year is your car?
blackink00 I missed a shift & stole Curt's money. Mar 30, 2005 545 0 0 Tempe, AZ Apr 23, 2006 #9 Apr 23, 2006 #9 i got a 98 so its pretty much the same
A a97mustang New Member Feb 2, 2006 61 0 0 Lincoln Park michigan Apr 23, 2006 #10 Apr 23, 2006 #10 well i have a 97 and only saying grinding for front because if not your front tires will stick out and look funky.or dont grind and get wheel spacers front and rear.
blackfang Founding Member Dec 17, 2001 1,290 1 39 Richmond, Va Apr 23, 2006 #11 Apr 23, 2006 #11 spacers for the front 7/16ths and no spacers needed for the rear.
Cook89Notch Founding Member Jan 17, 2002 3,201 8 59 Close to Lansing, MI. Apr 23, 2006 #12 Apr 23, 2006 #12 blackink00 said: i got a 98 so its pretty much the same Click to expand... alright, thank you.
