Pulled 2 codes last night-need advice
mhissticobra
61
I was driving then all of a sudden, the dreaded check engine light came on, went to Autozone to scan it and it popped up 2 codes. 0175 and 0172 which are Bank 1 too rich and Bank 2 too rich. I recently installed a Pro-m MAF, BBK Cold air kit, BBK throttle body, but after I installed all of that, it ran fine for a week, then boom all of a sudden?? Any ideas? BTW I disconnected the battery when I installed everything.
Do you have the flow sheet for the pro-m, if you do you need to show it to your tuner or if your not tuned you should get a custom tune. Having an MAF that is slightly off will make the car run fine but will eventually throw codes.
It's the MAF!!!!!!!!!
You computer was still learning for a few hundred miles after you connected the battery back up, then it went rich. Or, if you did not disconnect the battery, then you should have.
Sell the MAF anyway.
