If everything is removed that should be, you may just need to use a pry bar a little. Once the trans is off the dowels it should be loose then you have the fun of twisting and turning the thing to get it out. My suggestion is once you have the trans out of the car, cut off the right ear on the trans. Its pointless because no wiring harness goes on that side and about all it does is make install and removal harder.
