Take out all the spark plugs.
Install a pushrod for intake and exhaust on one cylinder.
Setup your valvetrain with checking springs on the intake and exhaust on said cylinder.
Use a dry erase marker on clean valve stems.
Hand crank the engine over a few times.
remover the rocker and check your witness marks. They should be centered and .060" or smaller in width.
If they aren't centered or too fat, you will have to buy some adjustable pushrods and measure out for the lengths you need.
