Question about explorer brake pads...
Discussion in 'SN95 V6 Mustang Tech' started by ganador01, Dec 15, 2003.
  1. I recently installed some brake pads on my friends explorer...but i did not put the little skinny metal shims the shims do anything? he wen't to a mechanic and the mechanic made it sound like the shims were extremely important yet the brake pads i took off didnt have them...any insight to this non mustang question?
  2. You mean the anti-rattlers, or the paper things?
  3. they are metal shims...about a milimeter or 2 wide...the same size as the back of the brake pad...
  4. come on...someone has to know...:shrug:
  5. Ganador, you mean the anti-squeel shims. Has an adhesive backing and attaches to pads itself. The fronts come with them but the rears do not. They need to be installed, keeps the brakes from squeeling like a pig as they wear on. The rears do not come with them because you are suppose to reuse the old clips. Each pad has 2. I suggest buyng new ones at the dealer, they don't cause that much. It is worth it cause you don't want to use old **** anyways.
