Progress Thread Raceoholic330's Restoration Thread. Dart 331, Turbo, Irs, Etc...
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by RacEoHolic330, Nov 14, 2011.
  1. TrophyHead
    TrophyHead Active Member
    Mar 19, 2003
    1,248
    24
    39
    PA
    Optima batteries are not a true sealed design. They do have a vent on them. Just do not want you to buy a optima thinking they are sealed.
    Keep up the awesome work!
  2. RacEoHolic330
    RacEoHolic330 I like to dress like a pretty girl SN Certified Technician
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    Thanks man. Good point about the optima. Spill-proof would have been a more accurate word. That, and the fact that they have glass mat cells that should typically not need to vent under normal charging.
  3. 84Ttop
    84Ttop They make new pistons every day, so why worry? SN Certified Technician
    Jul 3, 2009
    2,329
    844
    134
    South Jersey
    If you go Optima, I prefer the Yellow top deep cycle batteries. My friend uses one and can leave his electric assesories on for hours and never worry about a dead battery. Even the nitrous bottle heater has yet to keep this thing from starting. Wiring is tedious. I remember 3 straight days of just wiring when I did my car and that was everything from scratch!
  4. RacEoHolic330
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    A yellow top would be great. I found a local deal on a red top that I couldn't pass up though. Wiring is definitely tedious. I'm enjoying it though. The cursing will begin when I heat everything up and nothing works :confused:
    I bought a nifty TFI relocation kit from McCully racing. The stock TFI location is a known problem on our cars, and the heat from the turbo isn't going to help anything. The kit relocates the TFI outside the engine bay via a shielded harness. It also comes with a modified SN95 heat sink. All you need to do is remove your TFI module, plug in the harness to the three pins on the distributor, and then run the harness to your remotely-mounted TFI. The only thing I didn't like about the kit is the idea of having three spade connectors sticking out of the distributor. It doesn't look right, and I worry about them vibrating loose. I decided to modify the insides of an aftermarket TFI to basically turn it into nothing but a connector.
    Here's the unmodified inside
    [​IMG]
    I cut out the pieces that connect the terminals to the board. Somewhat hard to see.
    [​IMG]
    Soldered in jumpers
    [​IMG]
    Nobody will ever know
    [​IMG]
    Here's the whole kit with a Motocraft TFI module. The second picture shows the spade connectors that would have gone directly into the distributor. These will be cut off and spliced into a TFI harness plug. This plug will then plug right into the dummy TFI.
    [​IMG]
    [​IMG]
    It will look like a normal setup when it's all installed.
    [​IMG]
    I'm installing the TFI module and heat sink near the throttle pedal. There is a support post for the dash that I bolted it to. That will give me an easy spot to get to it if I ever need to replace it. I can also access the spout connector from there.
    stangboy likes this.
  5. RacEoHolic330
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    The engine is completely wired. I'm in the process of bundling up the harness and getting it into some wire loom. Some wires are too long and need to be trimmed and re-terminated. The only thing that I may need to change is how the fuel pump is wired. The panel only has a 15A fuse, but the Fuelab pump requires a 12GA relayed circuit and a 25A fuse. I have an e-mail into the company that made the panel to get their opinion on how it's best to wire the pump. I'm thinking another relay will be necessary. More pictures will be up tomorrow. Next will be running the feed and ground from the battery to the front of the car.
  6. madmike1157
    madmike1157 I neutered myself. >=-O SN Certified Technician
    Nov 30, 1999
    3,353
    667
    154
    Birmingham, al
    What are you using to wrap the wires/harness in? Please tell me its NOT that oil magnet convoluted stuff.
  7. Noobz347
    Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude
    Jan 5, 1985
    18,318
    2,033
    174
    Box behind Walmart
    Isn't the 25 amp fuse, installed in-line of the fuel pump? If so, the relay itself would be the only fused through the panel and it doesn't require much juice at all.
  8. RacEoHolic330
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    I'm not using the corrugated plastic split loom, if that's what you're referring to. I'm using a braided mesh loom.
    [​IMG]
    The fusing is always done directly off the 12V source feed to the relay, not off the feed wire directly to the pump. Here's the schematic for the Fuelab pump.
    [​IMG]
    What I can do to make this work is use what is now the output to the pump (stock color is pink/black) as the signal wire (blue wire above) to a new 30A relay. I can pull a fused 12V source off the battery and run it to the relay. I believe I need to keep the stock relay one way or another because of the way it's wired into the ECM. Unless the panel manufacturer has a more efficient way to do things, this will work. This is how any aftermarket in-line pump is wired in. The only difference for me is that I won't be powering an in-tank pump as well off the stock relay, so it's a little redundant to have a relay powering a relay.
    I'm also going to run a wire from the pump feed up to the dash so I can have a 'pump on' indicator light. The last thing I want is not knowing if I lost voltage to the pump.
  9. 188slo50
    188slo50 Member
    Oct 14, 2009
    52
    Well I read all 57 pgs and I must say your attention to detail is insane. What did you use on the shock towers to protect them from getting tore up from the CC plate adjusting? Cant wait to see this thing done and what your going to do to the interior!!!
  10. RacEoHolic330
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    Thanks a lot man. The tape on the strut towers is slick tape. It's an Ultra High Molecular Weight Polyethylene tape. Rick at RNH recommended it to use. It's pretty cool stuff.
    I finished up the modifications to the TFI wiring. Modified the plug and spliced the harness in.
    [​IMG]
    [​IMG]
    [​IMG]
    Most of the tape I'm using on the car, especially in the engine bay, is self-fusing silicone tape. I'm using some high quality electrical tape here and there as well, but I like the silicone tape because it doesn't make the wires all sticky if you need to cut the tape off for some reason. Once this stuff is wrapped over itself, it's not going anywhere.
    Here's the location where I mounted the TFI.
    [​IMG]
    I managed to start putting the engine bay wires in loom.
    [​IMG]
    Cleaned up the wiring along the floor. This will all get 1" loom. Somewhat oversized so the wires can lay out a little flatter under the carpet.
    [​IMG]
    Didn't get a chance to clean up the wires at the panel. Still a mess.
    [​IMG]
    BAP sensor location, as well as the route for the MAF sensor and O2 sensors.
    [​IMG]
  11. Noobz347
    Jan 5, 1985
    18,318
    2,033
    174
    Box behind Walmart
    Kill two birds with one stone and put a circuit breaker in the dash instead of using a fuse through the panel:
    http://www.partman.com/boat-systems...rs/breaker-30-amp-push-button-reset-only.html
    Who wants a light staring them in the face when the pump is working correctly? :D
  12. 188slo50
    188slo50 Member
    Oct 14, 2009
    52
    Got any links to that tape for the strut tower, my search showed nothing?
  13. RacEoHolic330
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    Do an Amazon search for slick tape. I used the 3" Peachtree stuff.
  14. Rick 91GT
    Rick 91GT SN Certified Technician Site Sponsor
    Nov 30, 1999
    9,747
    94
    99
    PA
    I use 3M 5421 or 5423 its UHMW if the cc plate sits flush I stick it right to the underside of the plate.
  15. RacEoHolic330
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    Got the Mcleod hydraulic clutch kit installed. Everything went in pretty easily. It took a bit of time to get the whole thing bled, but I eventually got good pedal feel. It definitely makes the Spec stage 3 feel a little bit easier on the leg.
    [​IMG]
    [​IMG]
    [​IMG]
    I also cleaned up the wiring around the panel. Looks a little nicer now.
    [​IMG]
    I have all this wiring done, but no power yet. Decided now is a good time to get the battery cables routed so I can start testing voltage on everything I'm installing. I wanted to route the cables away from everything so I drilled some holes and fished the cables through the rockers . Out of sight and out of mind.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I'm going to bolt an insulated post above the line lock solenoid. The battery cable will terminate there and then I can use that post to distribute power to the rest of the car. The ground cable will go to the block and a bolt I welded to the frame rail. Still LOTS more wiring to look forward to.
  16. madmike1157
    Nov 30, 1999
    3,353
    667
    154
    Birmingham, al
    In case I haven't sucked up enough, I just want to say that it's your car, (and it's build ethic) that I will emulate this time with mine. Running that big assed -0 gauge through the rocker is another one of those "why didn't I think of that" kind of things. Thanks for giving me another idea to steal.
    One question though,........what keeps you from running a rocker molding screw right into that cable?
  17. RacEoHolic330
    Mar 5, 2003
    3,349
    492
    123
    Allentown, PA
    Thanks Mike. Suck up all you want! And the battery cables are #1/0, for the record ;)
    I actually didn't even think about the molding screws, but that rocker channel is so deep that the screws won't come anywhere near the cable. The cables are laying on the bottom of the rocker, and there is probably 3" of clearance to the top. I'll double check the screws when I attach that molding to make sure they aren't excessively long anyway.
    I had thought about running all the ECU wires through the passenger side rocker, but the idea of fishing 50 wires (one at a time) through that small space was not very appealing to me. The harness will flatten out under the carpet anyway.
  18. Noobz347
    Jan 5, 1985
    18,318
    2,033
    174
    Box behind Walmart
    I have always Always ALWAYS wanted to checkout that hydro clutch setup.
    Curse youz! :fuss:
    Adopt me? :rolleyes:
  19. madmike1157
    Nov 30, 1999
    3,353
    667
    154
    Birmingham, al
    I got one word for you..............
    JJJJJTTTTTTT!!!!!!
  20. 84Ttop
    Jul 3, 2009
    2,329
    844
    134
    South Jersey
    I am really digging the hydraulic clutch setup, nice touch there!
Share This Page
