Progress Thread Raceoholic330's Restoration Thread. Dart 331, Turbo, Irs, Etc...
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by RacEoHolic330, Nov 14, 2011.
  1. GroverDill
    GroverDill GoldMember
    Aug 19, 1999
    4,764
    294
    114
    What will the high/low boost do? Will it have 2 different tunes? I like the USB port, looks great.
    stangboy likes this.
  2. MikeH686
    MikeH686 Mine is only two inches though.
    Oct 12, 2011
    1,937
    354
    94
    Did you ever pick a set of rear tires I might've missed it and I'm to damn lazy to search through 60 pages
  3. RacEoHolic330
    RacEoHolic330 I like to dress like a pretty girl SN Certified Technician
    Mar 5, 2003
    3,367
    604
    153
    Could be worse. At least its' not white ;)
    You got it, Grover. The switches are for two separate stage activations on the AMS-500 boost controller. The PMS also allows for multiple data sets, so I will use one set for a more mild tune and the other set for a balls-to-the-wall 100 octane tune. The USB port will be very handy to plug in the laptop. I just need to get a serial-USB adapter for the handset.
    @MikeH686, yes I did. 275/35/18 BFG G-force drag radials.
  4. MikeH686
    Oct 12, 2011
    1,937
    354
    94
    Let me know how they turn out for you I know you were debating on what to get at one point
  5. rdharper02
    rdharper02 Member
    May 8, 2006
    435
    Wait a minute. You get all nice and pretty and now you want to discriminate against those of us with white foxes?.............O.K., yeah, I kinda hate the color too. Thankfully mine has the red interior trapped by the cage, giving me something to hate more than the exterior color.
    Cant wait to hear how well the PMS works out. I may sell the AEM and try that direction.
  6. Noobz347
    Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude
    Jan 5, 1985
    19,555
    Showcase:
    58
    Albums:
    2,386
    174
    Yeah, Race robs banks for a living so he has the time and the money. :stir:
    This forum was originally founded by a group of guys who got together on-line, to create his alibis. :SN:
    True Story!
    :trollface:
  7. RacEoHolic330
    Mar 5, 2003
    3,367
    604
    153
    In all serious @rdharper02, I love white foxes. I think white is the best engine bay color when clean.
    @Noobz347 , you were supposed to go with me on my last heist. Way to bail. Now I have no money to pay for the rest of my wheels, and it's all your fault.
  8. Jersey Joe
    Jersey Joe Active Member
    Nov 30, 1999
    102
    Showcase:
    9
    Albums:
    42
    39
    What the hell were you thinking? Black Mustang...you must be crazy!
  9. stangboy
    stangboy Founding Member
    Aug 31, 1999
    3,514
    90
    69
    Hmm, I wonder if that can be done with a MSPNP. :scratch:
  10. Kumm3
    Kumm3 Founding Member
    Jul 30, 2002
    526
    25
    39
    Hey, did you have to cut apart any of your dash to get the gauges/gauge plate sit flush on the dash mounts? Im running into a clearance issue on my setup and if you have any pictures of what you had to do that would help me out tremendously.
  11. RacEoHolic330
    Mar 5, 2003
    3,367
    604
    153
    I didn't get to the point where I'm ready to mount the cluster to the dash. The MC Machine instructions do say that trimming is necessary though.
  12. Kumm3
    Jul 30, 2002
    526
    25
    39
    They mention it on their site, but they refer to a picture in the gallery that doesn't exist. I don't want to go hacking away without some idea of how much to cut.
  13. RacEoHolic330
    Mar 5, 2003
    3,367
    604
    153
    So the first attempt at starting the engine was made today. I wouldn't call it successful, but it wasn't a failure. Click for video.
    [​IMG]
    It's running pig rich. I pulled the #5 plug and it was completely black, tip and all. I pulled fuel during cranking on the PMS, but I need to mess around with the idle settings because it won't hold an idle long enough for me to even check the timing and fuel pressure. There is also a lot of smoke coming out of the breather. You can see it in the video. I'm basically using the tune from my supercharged setup, but now I have 95lb/hr injectors compared to 42 lb/hr with the old setup, so I need to account for that better.
    I'm happy it does fire up though, as rough as it may be. Oil pressure is good and nothing seized up or exploded. It's a start. Any input is appreciated. I'll check codes and mess with it some more another day. It's time for some football soon!
    A5literMan and 91chp notch like this.
  14. madmike1157
    madmike1157 the humor is still lost on me SN Certified Technician
    Nov 30, 1999
    3,706
    Albums:
    858
    154
    You're almost there. The whole thing is gorgeous.
    I want to know which RonFrancis kit you used. I'm looking for my replacement.
  15. RacEoHolic330
    Mar 5, 2003
    3,367
    604
    153
    Thanks Mike. It is pretty. I just need to get it to run. The oil has fuel in it, which is just lovely.
    The chassis kit is his Access 24/7 kit. Comes with factory connectors for the turn signal, high beam, and alternator connections. You tell them all the circuits you want and they take it from there.
    91chp notch and stangboy like this.
  16. 84Ttop
    84Ttop They make new pistons every day, so why worry? SN Certified Technician Mod Dude
    Jul 3, 2009
    3,054
    1,221
    144
    Alot of the times these things won't idle because of the fuel enrichment based on the coolant temp tables. This is one table that I almost always see overlooked. Try pulling fuel out of it at the colder coolant temps like when you have a cold start. Also, are you using an injector driver for the 96 lb ers?
  17. RacEoHolic330
    Mar 5, 2003
    3,367
    604
    153
    That's a good point. I didn't think about the coolant tables. I did realize I had way too much fuel in the idle settings. I remember having idle issues with the blower setup years ago and needed to add fuel to compensate. It's been a while since I played with the PMS. Gotta re-learn everything! I'm going to mess with the tables and lower my fuel pressure and then change the plugs and the oil. Gapping the 3923's at .030.
    And yes, I have a low imp driver for the injectors.
    91chp notch and 84Ttop like this.
  18. 90lxcoupe
    90lxcoupe Mustang Master
    Oct 8, 2003
    3,423
    165
    84
    Definitely can not be done with the PnP, you would have to build a custom board to have that stuff.
  19. stangboy
    Aug 31, 1999
    3,514
    90
    69
    Oh...oh well. :shrug:
  20. RacEoHolic330
    Mar 5, 2003
    3,367
    604
    153
    So I was re-checking all the tables in the PMS. For some reason I had +18 in the water temp table at -10 degrees. I remember troubleshooting a cold running issue with my old setup and that may be how I was trying to solve it. That +18 was adding a ton of fuel with the engine cold. Explains why everything was flooding out.
    The other problem I noticed is that the PMS is displaying -30 degrees for the air temp sensor. I pulled off the plug and installed another new (auto parts store) sensor. Still read -30 degrees. I shot it with the heat gun and it still didn't changed. I held the heat gun to the water temp sensor and it went from 54 degrees to 60 degrees in seconds. I obviously have some issues I have to figure out. Not sure why it doesn't work with two brand new sensors. That makes me a bit concerned. Time to do some EEC troubleshooting.
Share This Page
