im having a problem with my radiator fan.it goes on as soon as i start the car and does not turn off till i turn the car off. i have 96 cobra any feedback will be appriciated.
have you gotten a custom tune at all? somtimes they switch that so if you put in a cooler thermostat then it will run properly again. i assume the tuner would have told you if that was a possability though.
Does the fan come on when you turn your car to the on position and not actually start the car? Someone might of wired the fan to the ignition switch to have it constantly running to be able to run a cooler thermostat.
