- Sep 9, 2012
- 112
- 1
- 19
I have something really strange going on. I have a 68 mustang 302 with edelbrock 321/347 package and 500 cfm carb with performer intake. Recently started having start problems. Flamethrower coil was leaking and finally blew out. Changed to accel super stock coil and problem was fixed for about 2 months. Then suddenly same problem with starting came back. I rewired my ignition about 2 years ago using a 40 amp relay to make and break run wire from battery to coil +. Changed out the relay at the same time I put in new coil. Relay is made by run wire from ignition switch bypassing the resistor wire completely. My battery voltage reads 12.50. If I turn on switch I get 12.5 at + side of coil. Car still will not start or might once in a while. I even put dielectric grease on all connections at the relay and at the fuse that feeds the coil power from the battery. Two days ago I started blowing the ignition fuse when this problem started. Sometimes I can put a jumper from the battery plus to coil plus and get it started when I cannot any other way. The jumper seems to work more times than without it. but keep in mind I still have 12.5 volts to coil + without the jumper. A spark tester will show no spark when trying to start and doesn’t start. Tester will show good spark if I ever do get it running. Today I replaced the coil again. The first time I tried it it started right up but turned it off and would not start again. Finally got it started again with the jumper and drove it home from shop to see if you guys have any ideas. I am completely out of ideas.
To summarize all wiring form battery to coil is good.
Fuse is good.
Changed coil wire and is making connection or so it sounds like. I hear it click at both ends when I push it in.
Second new coil in 3 days.
Relay is new from yesterday and is making according to volt meter.
Have a pertronics ignitor. How can you troubleshoot one? It is only thing not been changed.
Any help or ideas greatly appreciated.
20a Relay n.o.
Battery +--------- fuse ----------0---| |----0----------+ ig coil
Ign switch +-------------------------rly coil----------grd
Fuse is good.
20a Relay n.o.
