Yes...the 3L08 stands for 3.08 gears with the trak-lock rear in the 8.8"...
The rest stands for where and when it was manafactured...and if I had to guess, you have an auto?
Sucks to have the 3.08s, but at least you have the good 8.8 rear...
Heres what I found when researching mine...
The first S stands for the Sterling Axle Plant.The 229C is the particular rear axle model build code.The 3L27 mean it is a "Trak-Loc" 3.27:1 rear axle ratio. Track-Lok is just a Ford owned name for their limited slip differential.The 6H09 refers to the build date. Your rear end was built on October 9th, 1996. 6 gives you the 1996, the H is the month, and 09 was the day of the month.
Sent from my SPH-L720 using Tapatalk 2
