Looks to have separate bulbs for both the low beam and high beam. I'm not sure what bulbs these use. Typically the projectors use a combination of H1 and H3 halogen bulbs.One being a low beam, and the other a high beam. I have seen some even use an H2, but rarely. Remove the bulb then look at any numbers stamped on the side of it or on the glass. An easy way to tell, if the bulb has a wire permanently attached to the bottom, then it's an H3. Again, pull the bulb and look at the numbers on it. It should say H3 or H1 on the side or bottom or a part number that you can look up and a bulb type will come back.
