I have a used set of svo 1.6 rockers and twisted wedge heads I bought as a set. My ? is being fairly new to pushrod motors, I took out the rockers and set them onto the studs, the bottom of the rockers seem to rub a bit on the nut portion of the studs and the rocker tip doesn't cover the valve stem much, is this normal?
There a slight wear marks in the bottom of the rockers, but not on the studs. And I figured the roller tip would cover the valve stem more. All of this is with them not tighted down eather. maybe it would change, but I didn't want to tighten them without asking you guys first,, thanks
