saleen hid, ford oem hid or kit converstion which is the best route to go?
Discussion in '2005 - 2009 Specific Tech' started by mandoq, Oct 5, 2008.
  1. mandoq New Member
    Oct 2, 2008
    Message Count:
    Hi, im looking at getting some hid headlights but dont know what to get. Do you guys thing i should get the saleen or ford oem hid which are like $900 or get xenon kit converstion for like $250. Its the xenon kit a true hid and will it look bright like the whole saleen hid headlights.
  2. Power4 New Member
    May 10, 2004
    Message Count:
    223
    What model year Mustang do you have? I've heard unless you have an '08+ installing the Ford OEM HIDs is a total ****.
  3. mandoq New Member
    Oct 2, 2008
    Message Count:
    I have a 06. whats the diffrence between 06 from an 08?
  4. NastyStang113 New Member
    Sep 12, 2008
    Message Count:
    1,591
    Why?
  5. Power4 New Member
    May 10, 2004
    Message Count:
    223
  6. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    I heard that too. OEM Ford HIDs require their own wiring harness to be spliced into the existing 05-07 harness and that can get messy.
    Any aftermarket kit will come with adapters for easy plug and play operation so the choice is between Saleen and Conversion. The Saleens will give you the most legal setup by having the correct reflectors and lens housings that are DOT legal. The conversion won't have that but will be significantly cheaper.
  7. whyask New Member
    Apr 4, 2005
    Message Count:
    766
  8. walter Founding Member
    Aug 13, 1998
    Message Count:
    1,068
    46
    That's the kit I'll be going with but in 35's though because imagine the power drain on 3 pairs of lights :)
  9. whyask New Member
    Apr 4, 2005
    Message Count:
    766
  10. ixmotoxi New Member
    Sep 6, 2008
    Message Count:
  11. metroplex New Member
    Sep 7, 2003
    Message Count:
    398
    The wiring shouldn't be messy. The harness is a mirror of our harness. The ballast just needs +12VDC from the low beam. The high beam +12V is used for the solenoid.
    The problem is that the OEM assembly costs $1000 from Steeda. If you have money to burn, go for the OEM assembly.
  12. rkaiser58 New Member
    Apr 23, 2003
    Message Count:
    14
    I have a 2010 with Halogens, and picked up used HID assemblies from a 2010. I noticed that the light plug is 3 prong on the Halo's and 4 on the HID. How easy is this to set up?
    Thanks.
Share This Page
