Ok, here's what I did and it works perfectly. When I took off the air tube where it connects to the back of the heads there are those two blocks. Take a hacksaw and cut those off. Now, take some high temp gasket stuff and flip the blocks over so the flat side plugs the holes. Remember the left side block will now go on the right side and vice versa. Take the bolts and screw them bad boys back in.
I've also heard that the threads on a spark plug are the same so you can screw one in and bust the rest off.
