Okay, I have been battling this problem for a while now.. What it is doing is that it is smoking really bad out the passenger side only. I can hold the RPM's at 2200 and grey smoke literally is pouring out. I have done the intake manifold gasket, just did valve stem seals, bottom end is all new, compression is at 152 all around right on the dot, heads have all been gone through. I am starting to think its a carb issue. The carb has been rebuilt, but I know nothing about tuning it, or on how to find what could be causing this problem.
The engine is a 351w, carb is a Holley 600 double pumper. It has been rebuilt using one of those trick kits, but the guy who did it for me pretty much rebuilt it then put it on and that was it. When the car is warmed up, it will idle at like 1500 rpm. I dont hardly know anything about carbs, I set the bowls and put the metering screws to get the highest vacuum which is 12 inches of vacuum at idle.
Any help on where to look or what I need to do to make this thing stop smoking? Its pretty much the only thing that is preventing me from driving the car since it smokes so bad.
