sneezing through intake popping
Discussion in 'Fox 5.0 Tuning' started by NoFearXStangFrk, Jul 4, 2006.
  1. NoFearXStangFrk New Member
    Jul 25, 2005
    Message Count:
    recently put e303 cam and edelbrock performer heads on car also converted to mass air heads have adjustable rockers and have set to 0 lash plus 1/8 turn but i still get popping in intake at low rpm on accell timming is set to 14 initial and running aod trans with bbk exh any idea what to try next?:shrug:
  2. Mike92GT Founding Member
    Jan 24, 2002
    Message Count:
    592
    Probably not related to your problem, but most people go about 1/2 turn on the rockers after zero lash. What mass-air meter are you using? Are you using an adjustable fuel press regulator?
  3. NoFearXStangFrk New Member
    Jul 25, 2005
    Message Count:
    I started with 3/4 turn after 0 lash and it is a stock mass-air meter and a stock fuel pressure regulator
  4. Mike92GT Founding Member
    Jan 24, 2002
    Message Count:
    592
    It's sounds like you might be getting a "lean pop", it's fairly common when you switch cams. I would get an adjustable regulator and a guage, and then try playing with your fuel pressure
  5. NoFearXStangFrk New Member
    Jul 25, 2005
    Message Count:
    Thats the thing though, it smells like its running a little rich
  6. aleborjas New Member
    Sep 12, 2005
    Message Count:
    625
    you have lean problems get more fuel presure...
Share This Page
