So I figured out why I dont see anybody with linelock on their cars.....
Discussion in 'Fox 5.0 Talk' started by Aliate X, May 4, 2006.
  1. Aliate X New Member
    May 9, 2005
    Message Count:
    649
    9
    Probly the worst thing Ive ever tried to install on my car. I bought the hurst roll control a while back and finally decided to install it while just the shortblock is in the car. What a mistake. First of all, while the rest of the brake system is standard, the solonoid is metric, so you have to use all these retarded adapters.
    I dont understand how this is possible to do with the motor in the car. The switch and the light that come with the kit look retarded, the light looks like something off a ferris wheel, and the switch can only be mounted directly on the shifter, and they just assume you have a hurst shifter.
    I hate linelock.
  2. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    I know a guy who had an older crown vic with a carb'd 351 and he empty'd the rear portion of his master cyl and only ran front brakes (no fluid for the rear) and that thing would do the meanest brake torque and sent tire smoke every where. I don't knof if he did this or just blew a rear line but when my friend bought it off him to make a demo car we seen all this and laughed our asses off.
  3. JimBowy Member
    Nov 8, 2003
    Message Count:
    391
    i just wired my own linelock button on the dash.... i dont need a light... if linelock isn't holding i'll know when the car lurches forward!
    its hard to see, but its the square-red-button just behind the steering wheel at 2 o'clock
    [IMG]
  4. poneypower89 Now everyone in the world will know I wanna bang t
    Dec 6, 2004
    Message Count:
    924
    28
    thats more like 2:30 :rolleyes:
  5. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    I was going to say that but I thought na I won't be an ass lol
    **edit not calling you an ass......well I guess I kinda did
  6. Aliate X New Member
    May 9, 2005
    Message Count:
    649
    9
    I think Im just going to wire it to a toggle switch w/ a light.
  7. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,027
    18
    78
    A lot of 4.6 guys have had great success with the SLP line lock kit. Not sure if they (SLP) have a kit that works well with the 5.0 Mustang or not (have not looked).
  8. Aaron'S'tang New Member
    Nov 10, 2005
    Message Count:
    73
    I was just thinking about getting line locks. Is this not an easy install on an 89 LX 5.0?
  9. Aliate X New Member
    May 9, 2005
    Message Count:
    649
    9
    Its an easy install in theory, but it takes a lot of patience.
  10. snoboardcore New Member
    Mar 31, 2005
    Message Count:
    280
    i installed my linelock and it wont even work right. It wont hold the tires enough to stop the car from rolling while doing a burnout.
  11. JimBowy Member
    Nov 8, 2003
    Message Count:
    391
    1. pump the brake hard a few times, hold the brake hard
    2. press and hold linelock button
    3. release brake
    4. if you find yourself moving forward when using LL, pump the brake again (while the button is pressed)
    5. proceed to smoke the tires
    6. release button and launch a 1.6 60'
  12. lxwants12's New Member
    Sep 22, 2004
    Message Count:
    520
    arent are brake systems a lil different a buddy of mine tried using the moroso LL and it didnt work it would hold the rotor for a sec then release it....arent our brakes like a diagnoal split system or something??...i would like line lck but since he had a bad time i was like ****it.....i mean i haev been good without it for years.....but i would like it .....
  13. snoboardcore New Member
    Mar 31, 2005
    Message Count:
    280
    Tried that doesn't work my vac is to low for it 8-10 when i hit the brakes go to the floor when i go to re-apply the brakes again they dont stiffen up and goes to the floor i can do it 20 times and it wont hold. it has 12 volts so im pretty sure its a bad solenoid.
  14. Aliate X New Member
    May 9, 2005
    Message Count:
    649
    9
    Did your pedal always do that? Like you press the brake all the way down and it slowly keeps going until it hits the floor? If so your master cylinder is bad.
  15. snoboardcore New Member
    Mar 31, 2005
    Message Count:
    280
    master cylinder is fine i have awsome brakes in the car just at an idle i only get 8-10 for vac because of my cam and because the cars have vacum assisted brakes it doesn't like to make brake pressure.
  16. Aliate X New Member
    May 9, 2005
    Message Count:
    649
    9
    oh what cam is this? Im asking b/c Im about to throw in my TF stage 1 along with the rest of the TFS kit.
  17. snoboardcore New Member
    Mar 31, 2005
    Message Count:
    280
    wolverine 1190
  18. PoopDawg Autozone Junkie
    Jun 21, 2002
    Message Count:
    1,408
    36
    It took me 30 minutes to install the linelock on my 83... Bought the JEGs kit and install kit. And it worked ohhhhhhhhhhhhhhhhhhhhhhhhhhh soooooooooooooo good!!! It helped me break in (bald) my drag radials. :D
  19. Curse New Member
    Apr 8, 2004
    Message Count:
    802
    I had read over on the corral, that SLP was going to make a kit for the 5.0s, don't know if the decided against it.:shrug:
  20. Aliate X New Member
    May 9, 2005
    Message Count:
    649
    9
    did that come with pre bent lines?
Share This Page
