Drivetrain Speedo Gear? 87 Gt, T-5z, 3.55, 255/40/17
Discussion in 'Fox 5.0 Mustang Tech' started by 87MustangGT, May 29, 2013.
  1. I've got an 87 5.0 with 3.55 gears. I recently installed a rebuilt T-5z, and plan to install some 255/40/17 rubber on 17x8.5's. What speedo gear will I need?
    As an aside, I assume (since the LRS website states "Requires a 1/8" spacer when used on all 79-86 cars or 87-93 4cyl cars.") that these will fit my GT without rubbing...?
  2. Considering you mention you rebuilt the T-5Z...which speedo drive gear did you use? Black 8-tooth, or yellow 7-tooth?
  3. Is this regardless of the drive gear? And, doesn't overall tire height fit into it? Based on the link below, it seems like 255/40 might be just outside a stock height tire (255/45s would be perfect, for comparison)
    http://www.discounttiredirect.com/d...1987&mk=FORD&selectedModel=MUSTANG&vid=006900
    I didn't personally rebuilt the tranny...and I didn't check before it was installed. What, aside from the obvious, is the difference between the two drive gears? And which driven gear would be appropriate depending on the drive gears?
