I have a '65 F250 and I'm in the process of putting a '73 F250 front suspension on it so that I can get the dual piston front discs.
Anyway, I was replacing the rotors and one inner bearing was seized onto its spindle. I cut the cage off with some snips and heated the inner race to get the bearing off. It came off very easily with a little heat. The spindle itself looks a little dark, but there aren't any gouges in it or anything. I used some steel wool to clean it up and tried to install the new rotor.
Well the rotor doesn't easily slide on like it should. I torqued to 25 foot pounds and there are only a few threads sticking out past the nut (not enough to install the cotter pin.
So what should I do? I'd really prefer not to take the spindle off - kingpins are a royal PITA!
