Squeaking in ?clutch?? of 96 cobra?
Discussion in 'SVT Forum' started by 96whitecobra, Mar 5, 2004.
  1. 96whitecobra New Member
    Mar 1, 2004
    Message Count:
    I have a 96 cobra that is fairly stock with 81K. It has a squeaking noise that happens only when the clutch is all the way out that sounds like a belt or something, but I can't figure out how that would be connected to my clutch. If I press the clutch in even a quarter inch or so the noise goes away. Ideas?
  2. Cobra X Founding Member
    Nov 6, 2002
    Message Count:
    128
    Wilkes-Barre/Villanova, Pennsylvania
    My car does the same thing, and I only have 44k miles. I've been told it is caused by a bad Throw-Out bearing. I'm not positive though.
  3. 96vert Founding Member
    Mar 7, 2002
    Message Count:
    360
    Columbus, Ohio
    me too!
    Mine does it every once in a while, and I have under 20k miles. It is a bad throw-out bearing. I'm waiting for the clutch to go before I replace it though...
  4. SVT32VDOHC waiting for the next hack atta
    Nov 23, 2001
    Message Count:
    4,423
    68
    Motor City
    I would say the same thing, throw out bearing. If you choose to replace it, do a clutch too of course, because you have to pull the trans for both.
  5. blk32V New Member
    Apr 10, 2003
    Message Count:
    130
    Portage, IN
    Yeah, defininetly sounds like a T/O bearing. If and when you do replace it buy the heavy duty (Valeo) throw out from D&D performance its 20 bucks and mine is quiet still and I have about 15,000 miles on it. You should also replace your pilot bearing while you have it apart. Replacing the clutch and maybe even replacing the flywheel with a lightweight unit would even be a good idea. Good luck and keep us posted
    Tim
Share This Page
