Alright guys, there is this squeeking noise by the clutch every once in a while. It mostly happens in third gear ( thats when its the loudest). It doesnt happen at idle or when the clutch is pushed in. Im thinking its the bearing retainer ( not sure if its called that but its the piece that goes in the middle of the clutch fork over the thing that sticks out of the transmission)squeeking because of the clutch fork (that piece that u slide it in on the fork im thinking is loose so i will need a new one?). The bearing retainer is new and it was greased up when i installed it. It make the same sound before i installed the new clutch also.
Anything else it could be? can that piece on the clutch fork get looser or weaken?
