The MGW shifter and the Steeda Tri Ax shfiter are both good quality.frathouse said:Is it just me or is the MGW not the best? lol Call me stupid if they do not make it for the 05-06 yet but it's all the rage on the 99-04 boards. Smooth, Little to NO shift noise...sweet =)
adamb258 said:im holding out for an MGW. in past stangs have had pro 5.0, steeda and MGW. MGW blew them waaaay out of the water, its worth the wait to me
we do plan on making one and have actually done some initial design work but we have a gov't. homeland security contract we are working on this summer that is pushing back our car parts development to the fall :>(
regards
george
www.mgwltd.com
4159 mike padgett highway
augusta, ga 30906
706-793-1770
Pliskin said:Whats the difference between the Steeda Tri-Ax and the Steeda sport shifter? I know theres a $100 difference but what really is there besides that?
Long Stroke said:The $300 Steeda Tri-ax is a Complete Billet design with internal offset springs.
The Steeda Sport shifter uses a Factory shifter base (thin Steel), with a new internal shift lever, revised pivot ratio and billet aluminum shifter top with built in shifter stops. It's lacking the billet strength and offset springs.
I have tried both and honestly like the billet design slightly better.
To answer this question.....By Anthony05GT .... "and when you pull up on it, there´s a lot of up-down play".
This is because the shifter design with relation to the base and the internal shift lever, is a ball and socket type joint. The 05 Mustangs transmission already has springs to help "center" the shifter, therefore Steeda didn't use as strong as a spring (as in pre 05 Tri-ax's) to help it go from 2nd to 3rd automaticly by just pressing forward. This then leave the abilty to pull up slightly on the lever, which is the ball slightly coming out of the socket. No big deal at all, but why are you shifting up and down instead of front to back
Steve_05GT said:I have the tri-ax in my GT and I love it, but there are a few issues:
1) had to shim it to get it into 5th and reverse
2) recently the left detent spring crapped out and I have to send it back to Steeda to be reapired. It still works fine but it has about 1/2" of play when its in gear
