29C - Insufficient input from vehicle speed sensor.
66C - MAF sensor went below 0.4 volts during the last 80 warm-up cycles.
Since the battery was connected, spent time trying to set the base idle, so these may have been stored at that time. The following day, it was road tested & no longer died when rolling to a stop. Cold idle was erratic. Warm idle was 950rpm. Fully warm idle was about 700 rpm. May never get better with 30lb injectors, 76mm C&L MAF, 9AL EEC. At this time, there is no FMU & no "tune". FMU is out for analysis, possible repair, probable replacement.
Not sure why 29C is coming up, never had it before.
VSS is connected to the EEC. O/Y to pin-6 (VSS Gnd); DG/W to pin-3 (VSS hot). These are new wires that make the connection at C350 at the connector at the left hadn cowl where the VSS connects to the Speed Control Amplifier (p.104, EVTM). The interesting thing is the O/Y & DG/W go into the connector but no wires go out to the SCA. I have cruise (speed) control, so don't know why this is.
66C could be because we were attempting to set the Base Idle.
Computer is on the floor, MAF is buried inside the passenger side fenderwell. Have to remove battery to unplug connector. I've seen connector extensions, might have to get one.
Will test according to this at the computer:
Code 66 MAF below minimum test voltage.
Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables.
The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
Changes in RPM causes the airflow to increase or decease, changing the voltage output.. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow.
Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer. Be sure to measure the sensor output by measuring across the pins and not between the pins and ground.
At idle = approximately .6 volt
20 MPH = approximately 1.10 volt
40 MPH = approximately 1.70 volt
60 MPH = approximately 2.10 volt
Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
There should be a minimum of 10K ohms between either pin C or D on the MAF wiring connector and pins A or B. Make your measurement with the MAF disconnected from the wiring harness.
Tuning recommendations are not in the future, so please no recommendations to do so. I'm doing this "old school", there were no tunes & no dynos 20 years ago. Worst case, it's a Megasquirt.
