Stock 302 Dyno Results
Discussion in 'Fox 5.0 Tuning' started by GHL, Oct 11, 2009.
  1. GHL New Member
    Aug 21, 2009
    Message Count:
    11
    New Hampshire
    I had my '88 LX 5.0 Mustang dyno tuned this afternoon to get some baseline numbers before I start modding for more HP. Thought some of you might be interested in the results for a near original, low mile car. (The only engine mods so far are BBK cold air intake, shorty unequal length headers and off-road H-pipe and Dynomax cat-back system. Transmission is AOD with a Lentech valve body and TCS 2800 RPM stall speed torque converter.) Peak prior to tuning was 186 HP. After the tune it's 194 HP/241 TQ. Want to get it to 300HP. Think I'll get there with head-cam-intake work?
  2. 88blowngt New Member
    Jun 30, 2009
    Message Count:
    71
    Dover, Delaware
    Absolutely, my friends 94 Cobra on a Crane cam with 1.7s, Holley Systemax II intake and Edelbrock heads 1.94 valves and 1.6 exhaust put down 298 respectively, IIRC.
  3. vristang Advanced Member
    Mar 31, 2005
    Message Count:
    4,695
    66
    Seattle
    What kind of tune?
    Chip or fuel pressure/timing?
  4. GHL New Member
    Aug 21, 2009
    Message Count:
    11
    New Hampshire
    Tune was done with a programmable chip. Ultimately replaced the '88 code with one from 1993.
  5. ryangruhn Member
    Oct 6, 2000
    Message Count:
    54
    Thanks for the post! My car is almost exact to your "stock" setup.
  6. FastDriver Moderator
    Sep 6, 2001
    Message Count:
    2,398
    48
    That sounds right on for an auto trannied car. Good luck with your build.
  7. gixxerguy2004 New Member
    Nov 30, 2009
    Message Count:
    10
    easton, pa
    i agree you should deffinatly be able to reach 300 with a decent set of heads and a cam.
  8. voodookills31 New Member
    Nov 29, 2009
    Message Count:
    i have twisted wedge heads, a FMS x-cam, and a holley sytemax intake. and im making 280/310 to the wheels. i have a t-5 though, so you might see lower tq numbers or at least i would imagine.
  9. 2002BLGT Well-Known Member
    Dec 18, 2003
    Message Count:
    3,075
    56
    Bedford VA
    you might want to look into getting a tune unless you are on a wore out shortblock you should be making over 300rwhp with what you have
  10. 88Stang331 New Member
    Mar 30, 2006
    Message Count:
    245
    i have a new 331 custom cam with .555/.570 lift with 224/236 duration respectively, RPM II intake and TFS TW 185cnc heads not to mention full exhaust (bbk headers, O/R h pipe) and lightweight flywheel/drive shaft.
    Going to get it dyno tuned and hoping to put down about 320-350 at the rolling things.
  11. 88Stang331 New Member
    Mar 30, 2006
    Message Count:
    245
    I agree. I made 270/290 without a cam.
  12. vtecwho New Member
    Feb 24, 2008
    Message Count:
    98
    Those cam specs are just like the NX274HR cam. Actually, they are the same. I hope you did not pay "custom" price:nono:
  13. 1990MustangLX50 New Member
    Jul 12, 2007
    Message Count:
    90
    As you can see in my sig all i have is full exhuast, electric fan, 100% stock engine heads,intake,cam with 178k on it made 218/283 threw a t5
  14. RARE NOTCH Member
    Nov 3, 2007
    Message Count:
    76
    Ohio
    My 15000 mile no option notch with a offroad hpipe and flowmaster catback and 355 gears made 241rwhp and 311rwtq. And the motor was all stock right down the the air silencer and the timing was at stock 8 degrees to. I am having it dynoed next saturday because i did h/c/i and i am getting it tuned also. hoping to get a little over 300 to the tire.
  15. Repostyle Member
    Jun 11, 2005
    Message Count:
    571
    Portland, OR
    To the OP: A couple years ago my 90 ran the same numbers (196 rwhp) with an AOD, AC, ORH, flowmaster 2.25" catback, cobra upper and lower intake, and cold air with 160k on a stock tune.
  16. seedeezy Member
    Nov 27, 2009
    Message Count:
    42
    208 rwhp @ 4800
    266 rwtq everywhere basically
    This was on my 1990 gt that was bone stock except...
    -msd 6
    -underdrive pulley on crank and water pump
    -bbk unequal shorties
    -no cats and flows all the way out 2.5 inch
    -warm air snorkel
    -3.55 out back and a T-5 (id tag ending in 199)
  17. 89SSC18 Member
    Aug 3, 2006
    Message Count:
    405
    9
    18
    These cars can make some real nice numbers stock. My 5speed '88 vert with minor boltons made 239rwhp/298rwtq a couple years ago.
    I was shocked and happy
  18. voodookills31 New Member
    Nov 29, 2009
    Message Count:
    what did you make after your tune? a few people have told me that i shouldve made more with my HCI combo, but i could never figure out what was up....
Share This Page
