Discussion in '1994 - 1995 Specific Tech' started by Blaise805, Feb 13, 2014.
  1. Hello all I got the yellow 95 on the road it passed the smog test got it out of non op Then the **** hit the fan. My dad was driving it and he said it started missing then died. I have checked everything that I can think of. There is fuel pressure, there is power going into the coil but not out. I changed the ccrm no changes. The same time this all happened I lost the check engine light and when the code reader is plugged in it will not turn on. I need some direction of where to look. Thanks Randy.
  2. distributor would be my guess...happened to me I changed everything (distributor last ofcourse)
    the pip goes most the time,buy an aftermarket or a used one works.
    there is a way to test for it if you have a voltmeter and a Haynes repair manual,or internet I im not good at that maybe someone else will chime in. hope this is your problem
  3. Look at the ignition switch, ignition lock, and ensure power to the ECU.
    Let us know what you come up with.
  4. +1 on the distributor
    Pull the cap and check for play in the shaft.
  5. Distributor doesn't explain why codes cannot be pulled.
  6. exactly where do I check for the power going to the check engine system. I had a working light and was able to pull codes up until this happened.
  7. I pulled the cover off of the switch and noticed that the housing to the tumbler was broken and hose clamped together.I took the clamp off and the top half of the housing and the tumbler came out along with aplastic part with worn looking contacts that must have been mounted in there but I cant tell how. I have a donor car how do you remove the switch? I'm going to need the housing and all since this one is broken in two.
  8. I think what you're talking about is the ignition lock?
    If so, you put the key into it and turn it to the "ON" position. You should be able to locate a small hole either on top of the lock near its base or on the bottom of the lock near its base. You'll need something like a punch or small and long allen wrench to push into the hole. The ignition lock should then pop right out of the housing.
    Sorry I can't be more descriptive but I'm considerably more familiar with Fox bodies than I am SNs.
    Were it me.... I'd go right down to the local parts store and pick up a new lock for 30-ish bucks. They generally come with an instruction book.
    If the housing that the lock sits in is busted (something I read in your last post), then you should begin searching for a replacement column or take the one (in its entirety) from the donor car.
  9. The entire column or the upper part, also does the power supply to the check engine light slash computer come from that switch, The battery light and abs light still turn on.
  10. ya... I guess process of elimination, but if he has power at the coil I doubt that's his only problem...
  11. It would be helpful at this point, to get a picture of what is actually broken.
  12. power going in but not out to the distributer cap. I have seen this before on two bmws and it was the relay that supplied power to the ecu how ever I tried a different cccrm but that does not mean that it was in working order as it was out of the donor car.
  13. I'll take some pics tomorrow I thank you for the help. I don't give up we will fix this.
  14. No worries. While you're taking pics, maybe @jrichker has some insight.
    I think he might be similar to me in being a Fox guy.
  15. were you welding on your car at all?
  16. no welding
  17. I have an 88 gt too I love that car. I was messing around with bmw 6 series when my dad bought the 88 from his neighbor. They brought it to me on a trailer not running the interior all apart it was sitting for three years. The guy dumped money on the suspension then stopped. The long story short is I liked it better than the bimmers and kept it.
  18. I would too. Particularly if all the grunt work to the suspension was already done. :nice:
    Blaise805 likes this.
  19. Its the first mustang I have messed with I'm learning it looks good runs good needs a few more mods.
  20. Cranks OK, but No Start Checklist for Fuel Injected Mustangs
    A word about this checklist before you start: it is arranged in a specific order to put the most likely failure items first. That will save you time, energy and money. Start at the top of the list and work your way down. Jumping around will possibly cause you to miss just what you need to see to find and fix the problem. Don’t skip any steps because the next step depends on the last step working correctly.
    Revised 12-Dec-2011 to replace 10 pin salt & pepper connector graphic.
    1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch to the Run position. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
    A.) MSD or Crane ignition box if so equipped
    B.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed. See paragraph 5A – Using a noid light will tell if the PIP is working by flashing when the engine is cranking.
    C.) TFI module: use a test light to check the TFI module. Place one lead of the test light on the red/green wire on the ignition coil connector and the other lead on the dark green/yellow wire on the ignition coil connector. If the TFI is working properly, the test light will flash when the engine is cranked using the ignition switch.
    D.) Coil
    E.) No EEC or computer power - EEC or computer relay failure
    86-93 models only: EEC relay next to computer - look for 12 volts at the fuel injector red wires.
    Both 86-93 and 94-95 models: No 12 volts with the ignition switch in the run position on the fuel injector red wires. The relay has failed or there is no power coming from the ignition switch. Make sure that there is 12 volts on the red/green wire on the coil before replacing the relay.
    F.) No EEC or computer power - fuse or fuse link failure
    86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid. Look for a 20 gauge blue fuse link connected to 2 black/orange 14 gauge wires.
    G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire on the ignition switch with it in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position at the ignition switch but not at the coil, then the fuse or fuse link is blown.
    Note: fuses or fuse links blow for a reason. Don’t replace either a fuse or fuse link with one with a larger rating than stock. Doing so invites an electrical fire.
    Ignition fuse links may be replaced with an inline fuse holder and 5 amp fuse for troubleshooting purposes.
    H.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery.
    In 86-90 model cars, it is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire.
    In 91-95 model cars it is a black cylinder about 2 1/2" long by 1" diameter with a black/white wire.
    You'll find it up next to the starter solenoid where the wire goes into the wiring harness
    I.) Computer. Don’t replace the computer just because you don’t understand how it works. Computers seldom fail, it usually is a sensor or wiring problem that causes the problems.
    J.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
    K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red/blue wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
    Wiring Diagrams:
    See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
    Ignition switch wiring
    Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
    Complete computer, actuator & sensor wiring diagram for 94-95 Mass Air Mustangs
    AutoZone wiring diagrams: You can navigate to the diagrams yourself via Repair Info | and select the car year, make, model and engine. That will enable you to bring up the wiring diagram for your particular car.
    2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability: [/b]
    B.) Distributor cap
    C.) Rotor
    D.) Spark Plug wires
    Two reasons:
    Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 2-4 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
    If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the Schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
    C.) Clogged fuel filter
    D.) Failed fuel pump
    A.) The PIP sensor in the distributor tells the computer when to fire the injectors. A failing PIP sensor will sometimes let the engine start if the SPOUT is removed.
    A noid light available from any auto parts store, is one way to test the injector circuit to see if the injectors are firing. The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and try to start the engine: it will flash if the injector is firing.
    I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
    B.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
    C.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
    See the graphic for the 10 pin connector circuit layout.
    The injector power pin is the VPWR pin in the black 10 pin connector.
    D.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the EEC relay and the red wire for the 10 pin connectors.
    E.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
    It should be .5-.1.0 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
    6.) Spark & fuel pressure OK.
    A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
    C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently. If you removed the distributor, there is a good probability that you installed it 180 degrees out of time.
    HO & 351W 1-3-7-2-6-5-4-8
    Non HO 1-5-4-2-6-3-7-8
    E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
