would you go with the MM's? or will these ( http://www.laurelmountainmustang.com/Full-lengthsub.jpg ) do?Yes, you do.
I doubt it matters much.
FWIW, we used to race an 85 Gt with T-tops, you could shove your finger between the t-top and the roof edge. When you ran the course you could actually feel your finger being pinched by the chassis movement. Same thing with an 83 Z28 I used to race. So, after the sub frame connectors were put on the car, almost all of that ceased. Now your car probably doesn't have T-tops, but the structure still moves around more than you would think, that's why the connectors work so well. The suspension is supposed to move on the frame, the (stiif) suspension is not supposed to move the frame.
The laurel ones have a slightly thinner wall, but they're a deal no matter what
Just had my full MM installed this past weekend. Haven't driven it much since but it does feel tighter. Not a HUGE diffrence but noticable non the less.
finally drove the car and...... Night and day difference. All I can say is WOW.
I peeked under the car when I got home and the welds look so-so. The shop that I went to did the install on his alignment rack...
