hey guys i found a good deal on a supercharger with lower intake,plenum and throttle body off from an 04 cobra and was wondering if i could bolt this on my 03 gt. get at me thanx
It will not bolt on. there are so many other things that you would have to do it. By the end your going to be spending just as much as if you bought a new centri kit. You can get a Tork Tech kit which utiliazes the m112 blower, but i dont think it would be worth it. Just go with a vortech or a procharger.
Where shall I begin?How is tork tek better?
- The Tork Tech kit is much cheaper in both intercooled and non intercooled form
- The 5th Generation Eaton MP112 makes more power and torque than the 2.1L at comparable boost levels.
- The Tork Teck kit comes standard with components that are only available as options on the Kenne Bell (42lb injetors, Standard Large bore oval Throttle body, Cold Air intake and 90mm Mass Air Meter, dedicated fuel pump upgrade, 8-rib blower drive system, etc)
- Tork Tech is upgradable to a 1900 TVS blower for half the cost of Kenne Bells 2.6L upgrade. Despite their size difference, both are capable of 600hp
- The Eaton is proven the most durable and reliable blower on the market, bar none.
- Kenne Bell customer service sucks, where TT's does not.
...that was more than enough to sell me on them.
Speaking of TT - no one mentioned this kit which will make his supercharger work: '99-04 GT Supercharger-less Kit Using a '03/04 Cobra Blower
