crazypete said:You rang?
not to jack the thread, but my motor is back home as of this weekend. all i need is the lifters and it will be put together ill let ya know how your carb does in a few weeks hopefully
Been snowed in for a long time now and sorta fell away from the stang. But now with spring around the corner, I'm all fired up for it. Greasing down the entire bottom cause I "GASP" noticed a spot of rust down there!
So here is my input for the carb vs efi debate. EFI is a good system but costs a lot of money to tune and has a great many points of failure: fuel pump, FP regulators, dozens of sensors, injectors, wiring....as my esteemed colleage mentioned, its all 13 years old now. Plus you change something and now the EEC has no idea what to do with all the air. Well, now you need a recalibrated MAF, new injectors, another fuel pump....all $$$. I remember seeing pages of "which maf/injectors/TB should I run" threads. Also the uqiuitous "why wont my car start?" threads.
With carb, you have 3 points of failure: the carb, it's fuel pump and your ignition system. The fuel is easy enough to measure, the ignition can be tested with a timing light. The carb? I can replace my entire fuel metering system in the same amount of money it takes to replace a single MAF. I upgraded my heads? rejet = $5. EFI = new injectors $180 + MAF $200 + TB $100 (?), maybe new fuel pump = $75...well you get the idea. The jets take about 5 minutes to change while installing all that takes much longer.
Now about failure....when my efi died on the road....well, thats it. I'm getting towed home for a 1 week probing session to figure out which circuit is not cooperating. Last time my carb died (3 times now since I've converted 4 years ago, 1 intake leak, 2 carb base leaks, all fixed within 10 minutes once I got it home), I sprayed carb cleaner at it and restarted it.
Plus, you can stare at your EEC and you will have no idea what it's doing. Now you can stare at your carb and its very understandable. Levers, springs, pumps, cables, all stuff you can grok. If something goes afoul, your really can mcguyver a paper clip in there and drive it home.
If you dont like what your eec is doing...tough. You can get a chip or a tweecer, both $$$. If you dont like what your carb is doing, you walk up front and turn some screws.
Finally, daily driving. I DD this carbed mustang for 2 years and I have no complaints. I mean winter driving too (hence the greasing I mentioned above). Most of the folks that talk about non idling cars and pigs over carburate. Vacuum signal is EVERYTHING. People are so used to bigger is better and they slap a 750 on a mild 302 and then complain how their car has no throttle response. I run a 570 vacuum secondary on a custom cammed afr165 headed 302. Talk about throttle response!! It really pegs you into the seat, gets over 20 mpg, starts on the first or second turnover. Vacuum signal is EVERYTHING with a carb.
So I hope I put in a good argument for the carb side of things. Let me know if you need any help with your conversion if you decide to go for it.
Good Luck!
Pete
You rang?
Good Luck!
Pete
Crazypete has been gone a long time - maybe 8 years or more.You wouldn't happen to have a guide on how I could carb swap my 302, like what carb, fuel pump, etc to buy? I'm tired on having problems on my efi
Unless you are a total bonehead, it is easier to fix the EFI than to swap to carb.
