my car gets code after code, and mysteriously just dissapear. i had an 02 code but that went away after i put the holley pump in.when it went in the water, i changed the pump and i had some good spare injectors but i lost one, so i had to go to the junkyard to get another matching one. i also broke a bolt in the bottom intake so i took the bottom off to get it drilled out, then i put new felpro gaskets on the intakes. so really the injector or the gasket set has got to be the culprit because i drove this car around before the injector and pump install and it ran crappy but not like this, you know where i am getting. i am just trying to eliminate some possibilities. i think i have used some efi cleaner after the injector install but not sure. i don't think that stuff works too good.
