Well, I made one today. My combustion chamber is about 4"x2'. My barrel is like 2"x5.5'. Igniton comes from the endcap. I'm letting the adhesives set up tonight...... I will test fire it tomorrow.
I would have like to seen that one95WhiteVenom said:made one out of a coleman cooler one time i dunno if that thing ever came down. we were shooting the big bouncy balls well ok flaming bouncy balls.
GreenMustangGt said:here is my special combo...it works INSANE!!....this thing goes out of sight, sounds like a shotgun going off, and the potato will stay in the air for literally 3 mins.....here goes:
2" WHITE pvc pipe....4' long
2" to 4" Pvc pipe reducer
4" White Pvc pipe....10"
4" screw end endcap
After careful planning, and many trials, this proves to be the best combo for range. What i use for ignition is a sparkplug with a nut on the inside, half way down the chamber connected to a grill clicker, so it makes a spark.
The BEST fuel is the CHEAPEST hairspray you can find, it has the most alcholhol!
If your interested i can take pics of it.
grrrrrrr said:My buddy built one out of lead piping back in high school. Put a rock in front of the potato and a LOT of gas in the back. Blew up a tree about four or 5 inches in diameter with the rock, just like a 30.06 would do...
Here's a cool idea since we're on the subject. Take you a tennis ball cannister. Put two tiny holes in the cannister, opposite each other, say a 1/32 of an inch or so, whatever your smallest drill bit is. Take a punch and use it to poke a bottle rocket fuse up into a tennis ball. Take a syringe with a bit of gas and air in it, squirt the gas and air quickly into a tennis ball so it atomizes as much as possible. You want more oxygen than gas, so make it like a quarter shot glass's worth or so of low grade gasolene. Place the tennis ball down into the cannister and pull the fuse out one of your small hoses (you need a long fuse for this). Spray the hairspray into the hole. About half a seconds worth should work, THEN light the fuse. Run like hell and watch the show...
