Progress Thread The Gila Monster.
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by madmike1157, Aug 26, 2013.
  1. rdharper02
    rdharper02 Active Member
    May 8, 2006
    454
    27
    29
    Mike congrats on the finds. Not much help as far as temp, medium and die make-up, but why don't you make your own lenses. Plexi or a similar medium should work. Candy model paint gives you your red and the "black-out" look is "in". Clear it all and your good.
  2. hoopty5.0
    hoopty5.0 Mustang Master
    Dec 14, 2010
    2,962
    1,020
    134
    SW Houston
    Congratulations. In a single day, you managed to surpass me in a build that I've had going for months. I quit.
    88LX5.Oh, stangboy and RacEoHolic330 like this.
  3. RacEoHolic330
    RacEoHolic330 I like to dress like a pretty girl
    SN Certified Technician
    Mar 4, 2003
    3,653
    915
    153
    Allentown, PA
    Hurry up and start making some turbo piping. I want to see how you plumb that summa bi tch.
    Madd_Hatter_1979 and stangboy like this.
  4. madmike1157
    madmike1157 If I could only jump.........I'd bite your ASS!
    SN Certified Technician Mod Dude
    4,314
    1,373
    164
    Birmingham, al
    Ohh C'mon!! All I managed to do today was spend a grand. You've already did that months ago.
    I still have the rear coil overs to buy,.. and the m/c and brake prop valve before I can turn a wrench on the thing. Once I got that,.. Then I'll start working on it.
    Then,.... I'll pass you.
    JK,.....all it takes is money Collin.
    Long way off Scotty,..... I got a whole bunch of work that has to happen before I can even hope to start on the turbo stuff,... and another 1000.00 to spend.
  5. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    Thank you, Iweegian.
    Not as easy as that sounds,... the stock tails have a shoulder that sits in the "trough" that had the adhesive imbedded. A flat piece of lexan would have a gap that just wouldn't work.
    I'll probably end up making something custom just the same. The challenge is the same now as it was two years ago when I first laid a Sawzall on the back of my mustang,........ how will it look after I've gone past the point of no return.
  6. 95BlueStallion
    95BlueStallion Advanced Member
    Feb 22, 2007
    1,888
    198
    74
    Cedar Rapids, Iowa
    I am thinking '67 GT500 tails. Not sure how hard they are to find, or how expensive they are, but shape wise it seems like a good fit...
  7. Noobz347
    Noobz347 Stangnet Facilities Maint Tech... Er... Janitor
    Admin Dude
    Jan 4, 1985
    15,379
    1,640
    174
    Box behind Walmart
    Or maybe the Cougar sequential tails... :chin
  8. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    All three cars,.. the 67/68 GT/CS; The 67/68 Shelby,.. and the 67/68 Cougar all used the same sequential tail light,.. with only the exterior trim to differentiate them.
    The swap would be expensive,...(about 600.00) and require welding and body work. I'm trying to find a lower price solution before I commit to that.
  9. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    After looking at it based on info I got from another thread,... I decided to try a set of Fox tail's.
    The problem for me is,.. they will look like they are in fact fox tails.
    I'm trying to minimize the fabrication involved in this process, but that appears frugal. The fox tails have a slight curvature to them across their length, and are squared off at the side where they butt up against the quarter, Stupid Fairmont tails are not curved, and the mating surface at the quarter is cut on a diagonal. Mustang tails look to be 6.5" tall, Fairmont looks to be 8".
  10. jrichker
    jrichker StangNet's favorite TOOL
    SN Certified Technician Founding Member
    Mar 10, 2000
    22,449
    537
    164
    Dublin GA
    From your description, it sounds like you are going to have to make a filler plate. Acrylic plastic sheet is easy to work with and it could be the solution. Cut and shape the outside edge of the acrylic blank to fit the mount for the Fairmont taillights and cut and shape the hole in the blank to fit the Fox taillights. Paint the blank whatever color you like. If you don't like the idea of leaving the acrylic filler plates on the car, they can be your pattern to make some out of sheet steel or whatever else you might choose.
  11. madspeed
    madspeed Colonel Mustard
    Mod Dude Founding Member
    8,208
    1,177
    174
    a van down by the river
    how about somwthing on the lines of a Caprice or Bonneville light
    images?q=tbn:ANd9GcRtxPcxgfDg2gDlsWs3WD9kQBLZiM2_yZbl5RImPObss2eODonR
  12. mikestang63
    Aug 27, 2012
    4,500
    1,335
    154
    In the garage
    I think I found my new sig,,,, lol
  13. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    The problem w/any junk yard light is that they probably would be as bad as the crusty junkers I already have. If I go through the hassle of converting the tails to something different I wanna be sure that the parts sources offer new quality for my sweat.
  14. madspeed
    8,208
    1,177
    174
    though you were missing most of your lenses?
  15. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    :shrug:
    is'nt that the solution to all our problems?
  16. madspeed
    8,208
    1,177
    174
    do the standard Fairmont lights fit? I've got a buddy with a few, he likely has some spares
  17. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    No, Futura tails are significantly different than a box top.
  18. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    i am, but even the substrates are crumbling.
  19. madmike1157
    4,314
    1,373
    164
    Birmingham, al
    Okay,...actually bought Fox tail lights this morning, and w/i an hour, cancelled them. I just don't think I can make them work and look like they belong there.
    Shelby tail lights,.........now that is a different story.
    I hate that after spending all that money Saturday, I'm gonna have to pony up another 500.00 for a set of stinkin tail lights,..but that seems to be the way things go w/ me.
    Tomorrow,..I'll order them. I gotta make the entrire rear panel to accomodate them outta sheet metal,..but that will afford me several solutions to several dilemmas:
    #1. I effectively replace an obsolete part w/one infinitely more available.:nice:
    #2. I "fix" the retarded crap the ford design engineers screwed up w/ filler strips and foam inserts.:nonono:
    #3. I get that really cool sequencing action that comes w/ all Shelby turn signals.
    #4. Mike gets one more notch on the "unique" totem pole.:banana:
    stangboy likes this.
  20. Ryden
    Ryden Member
    Dec 25, 2012
    23
    14
    Love it. Hope you make it a super sleeper.
Share This Page
