- Dec 19, 2010
- 5,719
- 4,238
- 224
^^^ this. I hate to post this but in all honesty some of the reasons my heater core hasn't been replaced and I'm still rocking 4 lug. Both jobs are a pita. Staying 4 lug for me was also due to the fact that I already ordered 4 lug axles,etc and I liked my wheels. I will do both one of these days but I sure am not looking forward to it.(86's are even worse than the 87' up)Having serious issues with the install today. Fought the cobra booster for a hour or so and finally got it in after elongating the holes and beating the tower in.
Now, can't get the bottom line threaded into the turbo coupe MC so I gave up and ordered the SN one to use with then 3-2 conversion.
This is officially worse than the heater core.
Havent decided yet. Was going to put it in this weekend but brakes didnt go as planned.What are you going to do with your brand new PIMP setup?
Joe
The brake issue has been since I did the 5 lug swap. Initially, I thought it was becuase the MC was not moving enough fluid, but the problem persists now. I know I got the air out of the brakes. Bled the piss out of them.Did you do a good job bleeding the brakes? Maybe have some air still in there?
Possibly the prop valve needs to be adjusted to get more braking in the rear?
1. Didn't measureDoes that caliper match the other rear caliper? Same width?
Does your other rear caliper have the same piston travel as this one?
Are you thinking the piston has max'd it's travel and is not stuck halfway?
When you bled the line was there a good amount of fluid flow/pressure?
No leaks, creases, kinks or obstructions in that brake line?
The only one I can truly answer correctly is 3 - and I meant that it was like that when I did the swap. Initially, the caliper I had had a stripped out bleeder so it was junk and I went and got a new one (this one). Im thinking the issue is the caliper itself and may just need to replace it.... again.
