Hi gang. Long time listener, first time caller.
I've been reading and researching brake upgrades for my 93 fox for several months and based on Mike's great info (thanks btw!) this is the setup I went with...
93 Cobra MC
93 Cobra booster
99+ GT/V6 PBR fronts
94+ SN95 rears
It's my understanding that this is basically the same ratio/setup as the 99+ V6 as the 93 Cobra MC and the 99+ V6 MC are both 1" bores.
My problem is, my pedal is too soft and travels too far. The braking power is also underwhelming. I checked the booster to MC pushrod length. I double checked all my fittings/connections, no leaks. I bench bled the MC before install and bled the brakes. All my hoses are steel. Is there anything I'm missing?
I'm going to re-bleed the brakes this weekend just to make sure since the entire system ran dry during the conversion. Could it be something as simple as air in the system or should I consider going to the 1 1/16" bore MCs?
Thanks.
