boldsword
my car was an 87, maybe i spent to much time tinkering under the hood, but it did 120mph, sure it took about 7 miles to reach that speed, but I will swear upon my immortal soul that it did
Scott_95GT said:True, there is no reason to "fear" 4:10's or 4:30's, but why gear a street car like that? My friend has 4:10's in his daily driver, and he has to be perfect to get a good launch. On the freeway, he needs another gear. Meanwhile, another friend of mine has 3:73's, has more ease when launching, has a good rev at freeway crusing speeds, and still keeps the car in it's power band when mashing through the gears. Sure, at the track on sticky tires, the 4:10 are slightly faster (2 tenths tops). But the 3:73's are better all around gears. But I guess some guys like reving around 3000 doing no more than the speed limit.
5spd GT said:Why did you pick 138mph?
The drivetrains in a boat are different...and you don't see them last 150,200,250k
430's gears is just a cheap simple solution to give you the sensation of power but the longterm effects are not worth it...IMO
Hissing Cobra said:By the time your engine hits 150K, it's just about ready for a rebuild anyway. So, this argument doesn't make sense. Just because boats don't see that many miles, doesn't mean a thing. Engine wear in a boat is not measured in miles anyway, it's measured by hours. And, I've seen many boats with numerous hours and years between rebuilds while running at 3-4K rpm's and above.
Really? I'll be running low to mid 12's on a very streetable naturally aspirated Mustang which is awesome in traffic, idle's at 1,000 rpms smoothly with a solid lifter camshaft, and cruises comfortably at 80 mph on the highway with relative ease. The best of both worlds? No?
Hey, "Need a fast car," you're thinking along the same lines as a lot of top engine/performance people such as Ed Curtis, Mike Dez, and Eric Laferrier. If you need steep gears, don't be afraid to use them. With today's advancement of technology and overdrive transmissions, you truly can have the best of both worlds.
90mustangGT said:All this talk about longevity of the engine and miles-per-gallon made me have to check to be sure I wasn't on honda-tech. The last thing I am thinking about in a race is engine life and fuel milege.
For a drag car, a gear becomes too steep when you run out before the end of the track. If you can't get traction, changing the gear is not the answer. The point is that it all depends on how seroius you are about racing, and what kind of racing you are doing.
There is more I cold add but I am tired, goodnight.
5spd GT said:Is your car your daily driver?
The majority of the cars in this thread are daily drivers...I'm giving a daily driver perspective to "uping" the gears and reasons why there is no need...I don't see no drag cars in this thread...do you?
Gas mileage does matter...it is a good sign of how your engine is in tune...I would rather get 20mpg than 2mpg...but I guess I'm a ricer for thinking that
90mustangGT said:No mine isn't a daily driver, but not a race car either. I didn't say you were a ricer, but then again, what's more important when driving a Mustang, MPH or MPG? With gas prices as they are, yes you want decent gas milege, but I'd trade MPG for MPH or ET any day. Your right, engine tune has a lot to do with fuel milege, as well as everything else. If your getting 5-10mpg, it isn't the gear to blame.
5spd GT said:Well saying 150k doesn't mean you need a rebuild...bad argument there...some cars need it at 50k and some at 250k...
Yes I know boat "mileage" is done in hours...I have one...
Boat engine and mass produced vehicle wear is WAY different...
I'm talking about 4:30's not your combo...my car run's low 12's and I drive it every day and get 20mpg (city/highway)...with 373's
Cruises at 80mph with relative ease? Mine does it easy...but I have lower gears ...I'm not worried about your idle...I'm talking about gears...430's is to much...it is useless and is a cheap way for the "feel" of power...
Your right Ed Curtis is a top engine/performance engineer...look at sig on how I know ...he gives you suggestions to go quicker not gas mileage...so why wouldn't he suggest a steeper gear...he seen no problem with my 373's and I've got a pretty hefty cam (.560 lift)...
Ask Michael Yount if 430's vs. 355 gears will wear the engine out quicker...he will even do the math for you...
Good Luck with your car...
90lxcoupe said:Wy dont you let this thread die? if you take care of your engine and dont beat the piss out of it then it will last a long time whether you have 3.73's or 4.30's. and saying that using steeper gears is a cheap way to feel power is b/s, thats like saying doing suspension work is a cheap way to feel traction! gears are a tool to make the car faster just like heads or a cam. Personally i dont think your opinions are going to affect anyone because it is just that an opinion, and everone wants something different out of thier car.
id believe that you ran a high 12 with ur setup, but i'd like to see a timeslip of your LOW 12 second pass.
410's and a 5spd from the factory? Its a bit much,maybe an aod.355's with a 5spd.,,and 373's with an aod should have been an option from the factory.raph130 said:you took the words right out of my mouth. another example is like saying, heads and a supercharger is too much because you could get 500hp with both.so what nobody is gonna do heads and supercharger because it nets too much power?
please. if you can't handle it buy a honda. 4.10, 4.30's nothing crazy about it whatsoever. i personaly think mustangs should have come with 4.10's from the factory. they are way slow and underrated in stock form due to terrible gears. even a camaro has better gears than that. most 4 cylinder cars have better gears than that in the range of 3.45-4.30.
i can't stand lugging around and being forced to stay in one gear at a high rpm because going to the next gear would get u at idle so your better off in neutral while in traffic or slow driving around the city.
i got my stang apart right now. waiting for the rain to go away. im putting in a new transmission, clutch, 4.10 gears and a richmond spool. and im gonna melt those stock gears with my torch.
raph130 said:please. if you can't handle it buy a honda. 4.10, 4.30's nothing crazy about it whatsoever. i personaly think mustangs should have come with 4.10's from the factory.
