Just because your vert was trapping 103.7 doesnt mean if a cammed GT trapps 104 he is a bad driver. I for one have a cammed GT 2 280ish RWHP and trapped 104 at best. I went from 5500RPM shift points to 6300ish...best trap came about at a combo of 6-6200RPM shifts and a cool down. For instance, I went on a WED night with crappy prep. When i would spin and get a 2.2 60' the car would trap 101-102...when I hooked as best as possable 1.95-2.0s the car would trap 103-104. Its very possable for a cammed GT to trap 104. (and yes im a good driver
C&Pd from your members page:
*****Went
[email protected] with a 1.79 60' on Nittos @ FFW Orlando, full weight, stock
suspension, and sway bar intact(3625lbs+)***** with below mods
Modifications:
Chassis/Drivetrain:
-Welded in subframe connectors
-4.10s
-31 Spline Trac-loc
-Moser 31 Spline Axles
Performance:
-Steeda Underdrive Pullies
-Superchip
-Steeda Tri-Ax
BBK o/r X-Pipe
-Magnaflows w/turndowns-
Far cry from 103.7 that you get on SLICKS
(unknown weight reduction) Not to mention your track is 60ft above sea lv...mine is 660. My corrected times were 13.02 @ 106.3 BTW. STREET tires @ 30PSI and full weight. Track #s can be decieving due to weather, and you CANT compare traps when your using slicks(or even DRs really) and we are on streets. And you CANT say that if a cammed GT is trapping 104 then he cant drive.
Just thought I would point that out...your statement was too open. So it is possable.
EDIT: im NOT saying that this was not the case the day he went to the track( that the guys in cammed stangs couldnt drive) My above statement was for general use only, since your term seemed in general. My bad if you were meaning that they couldnt drive since he was also traping 104.
